The notification badge on my Messaging app icon is incorrectly showing 1 unread message.
I have a totally stock Droid RAZR MAXX HD running 4.4.2. My stock messaging app is version 4.4.2-10. SMS is set to "Messaging" (not "Hangouts"). All settings are default.
From my own troubleshooting, I have concluded that the problem is KitKat related since stopping, disabling, data clearing, cache clearing, and defaults clearing stock messaging app has no effect. Also, this problem started after upgrade to KitKat (never had it before). Further, after completely disabling the stock messaging app, I alternatively installed GO SMS Pro, chomp SMS, and Verizon Messages and experienced the same problem with each.
Any ideas about how to fix this problem, while leaving the phone unrooted, would be greatly appreciated.
Stuck Notification Badge on Messaging Icon
Posted 27 July 2014 - 11:46 AM
Posted 27 July 2014 - 12:08 PM
sent from my G3
Posted 27 July 2014 - 02:21 PM
Thanks, livinginkaos, for your response. I would FDR, but I would then have to rebuild my phone from scratch. That is, I haven't rooted my phone, so I can't fully back it up (with Titanium Backup, etc.) for restoration after the FDR. Also, although an FDR may work, the problem will likely recur if it is KitKat-related as I suspect. You know, this messaging notification badge problem first occurred right after my KitKat OTA upgrade, but I somehow corrected the problem. The problem went away for weeks. Now it's back and I can't remember what I did to get rid of it the first time. I know that it wasn't an FDR. I use Verizon and I'm beginning to think that the problem may somehow be related to their SMS/MMS servers or their Visual Voicemail feature and KitKat.
Posted 27 July 2014 - 03:10 PM
you can find all Messaging apps and turn off the Notification, its possibly on for one of them...if you think its VZW you can use the web browser and login from a PC to clear that, IIRC.
Posted 28 July 2014 - 02:16 PM
Thanks for the response, cmh714. The only messaging app left on my phone is the stock Messaging app (4.4.2-10) and notification is turned off (both in the app and in settings). I have no unread messages of any kind according to the VZW website and Verizon tech support claims (of course) that the problem is not at their end. I strongly suspect that it is related to either KitKat or changes made to the stock messaging app within KitKat.
Posted 10 August 2014 - 10:58 AM
