Raz-M Ver. 4.4 fails trying to flash system.img using RSD Lite
Best Answer livinginkaos , 03 August 2014 - 03:59 PM
All you need do is boot into fastboot, plug in the usb, open a command window in your fast boot directory, then type the following commands: fastboot oem fb_mode_set fastboot oem fb_mode_clear sent from my G3 Go to the full post
6 replies to this topic
#1 cmulder
cmulder
  • 15 posts
Posted 02 August 2014 - 03:37 PM
Have a Razr-M (XT907) and the over the air update to KitKat 4.4 was not installing. It would download the green android man would appear and start the download, but he would fall over dead and it would fail. Tried it after a system restore to original factory default still failed. So I tried doing it manually using RSD Lite (had to remove the "getvar" line in the xml file to get it to work. It completed 15 out of 20 steps (not sure how many steps there were) and on Number 16 (system.img) is says Phone returned fail. I tried to flash the previous version (since that had updated successfully but that failed on step 2). So then I copied the previous system.img to the new 4.4 install folder to see if that worked and that also failed.
So now I have a phone that of course does not boot. But it responds fine to RSD Lite, just won’t get past the system.img flash.  I also tried Matt's utility (choices 1 and 2) but I can't get past flash failure on bootup or "no valid PIV block in SP for system piv validation failed (system)  Fastoot Reason:  Boot Failure"
At this point, I would be fine getting back to the previous version or if someone could help with updating to current version that is fine. The phone is not rooted although I would be fine with doing that. Whatever get its working again.
#2 livinginkaos
Posted 02 August 2014 - 03:41 PM
Go here
[FXZ]-4.4.2-183.46.10
[FXZ] 4.4.2 183.46.10
sent from my G3
#3 cmulder
cmulder
  • 15 posts
Posted 02 August 2014 - 09:31 PM
Worked like a charm thank you!
#4 cmulder
cmulder
  • 15 posts
Posted 03 August 2014 - 12:14 PM
Well there is another issue now--not a big deal. When I power down and push the start button to turn the phone on, I get "Sticky bit factory_fastboot".  How can I get it to reboot normally?
#5 thewraith420
thewraith420
    Crack Flasher
  • 112 posts
  • Current Device(s):XT907 jbbl Blisspop
Posted 03 August 2014 - 03:52 PM
Here
#6 livinginkaos
Posted 03 August 2014 - 03:59 PM   Best Answer
  • cmulder likes this
#7 cmulder
cmulder
  • 15 posts
Posted 03 August 2014 - 08:19 PM
Wish I had seen that--followed the commands on another recommendation and it made my phone re-set to factory.  No big deal since I set it all up last night, it was much quicker today!  But the commands worked. The commands that worked were:
fastboot erase userdata
fastboot erase cache
fastboot reboot
My guess is I only needed the first two.  The "fastboot erase userdata" was the killer.  I didn't realize that would factory reset the phone.  But again, its about a 30 to 40 minute job to set up my phone from scratch.  I do it every so often just to have a fresh start.
