Safestrap 3 For Droid Razr M
ss safestrap droid m razr m droid razr m
16 replies to this topic
#1 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 07 November 2012 - 04:38 PM
has just released SS3 for droid razr m can be downloaded from here
i have yet to find any topics about it if there is any please leave links or to roms.
  • pmbasehore likes this
#2 Trylek09
Trylek09
  • 57 posts
  • LocationUSA - East Coast
  • Current Device(s):Razr M
Posted 07 November 2012 - 07:28 PM
  • Please Login or Register to see this Hidden Content
I wonder if this will work on the Razr M. And do you have to be on Stock ICS or can you be on the JB Leak. Also, it is still in Beta it looks like (for all phones). I do know the rooting method for the HD is the same as the M. The two phones have very very similar software versions.
#3 pmbasehore
pmbasehore
    geek
  • 26 posts
  • Google+:gplus.to/pmbasehore
  • Current Device(s):Motorola RAZR M running PACman 4.3, ASUS TF101 running KatKiss 4.2.2
Posted 08 November 2012 - 10:26 AM
Wow, that's news to me. I can't find much about it on XDA or Rootz, either. Anyone know anything more?
EDIT: Found this on Hashcode's blog:
And the tweet that led me there:
Droid Razr M, running OSE 4.4
Transformer TF101, running KatKiss 4.3
#4 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 08 November 2012 - 12:22 PM
im running it on JB leak and it works fine... the only thing as hashcode had said use only for back-ups and restore only at the time... either he has to do something with rom booting or just the lack of roms.. but it does work on the Droid Razr M.
#5 Trylek09
Trylek09
  • 57 posts
Posted 08 November 2012 - 03:21 PM
Sweet! Thanks!
Edit: Did you install it from JB?
#6 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 09 November 2012 - 06:52 PM
Sweet! Thanks!
yes it works in both ICS and JB confirmed
#7 Trylek09
Trylek09
  • 57 posts
Posted 09 November 2012 - 06:58 PM
Every time I try to install it from JB, Im getting a force close error when opening the SS recovery app. Its on my SD card (external). Im not sure what Im doing wrong.
Following these steps
#8 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 09 November 2012 - 07:04 PM
follow this steps and see if it works...
i read somewhere that if it dont work try uninstalling recovery which is done from Safestrap, than delete the app its self, than wipe dalvik and than redownload the app and reinstal it and follow steps thereafter.. i didnt come across this problem, but i did have a force close on facebook but i just re installed it.. i cant blame SS because i dont know for sure if it was that app. but it was all easy fix... good luck
#9 Trylek09
Trylek09
  • 57 posts
Posted 09 November 2012 - 07:18 PM
I think I found my problem. I just noticed it doesnt seem new apps that require root arent recognizing my phone IS rooted. The apps I already had that require root (like adfree, wifitether, es explore root, system app freezer) are all still working. Terminal Emulator says "access denied" when I try to access root via "su" command.
im at work at the moment, so I can't access the site you gave me yet. But I think I better try re-rooting my phone first and if that doesnt work then I might need to restore ICS, reroot, then SS3....then JB leak
#10 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 15 November 2012 - 04:54 PM
Official support thread is here now:
I needed some time to work out the "kinks" on this release. Been using the HD folks as guinea-pigs. :)
#11 Trylek09
Trylek09
  • 57 posts
Posted 26 November 2012 - 07:44 PM
That's awesome you posted this. I was just installed SS3 for my replacement Razr M :) If you need a guinea pig for Razr M... ill do it! I am sue-free!
  • RzrMike likes this
#12 betasu
betasu
  • 9 posts
Posted 02 March 2013 - 03:32 AM
I installed SS3.11 to my Razr M, but it did not work. Now I installed SS3.12. After reboot, a splash screen appeared. But there is no "menu" button at all.
I tried several times, however, the 'menu' is still unvisible.
Give me a tip, please.
#13 RikRong
RikRong
    Cap'n Slow
  • 2,115 posts
  • Twitter:@rlongjr80
  • Current Device(s):Moto X Pure 2015 / N7 2013 / RazrM
Posted 02 March 2013 - 04:54 AM
When you are in the splash screen, you should get a "recovery" and "continue" button. Hit the "recovery" button to enter menu.
R. Long: Nexus 5 on Carbon / Slimmed N7 2013 / RazrM stock KK
#14 betasu
betasu
  • 9 posts
Posted 03 March 2013 - 08:31 PM
I also removed the app and the folder in sdcard, rebooted, reinstalled the app. But Unfortunately, still nothing. i only have 'safestrap disable' & 'starting system in 10 seconds' in the splash screen. There is no any virtual button.
Shall i try some physical button, like power / volume?
Many thanks.
#15 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 03 March 2013 - 08:35 PM
Many thanks.
Are you sure you got the right safestrap apk?
#16 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 03 March 2013 - 08:45 PM
guys i dont know how to put a request for post to be taken down... but dont use this for the SS... hascode has made a tread for it which he will maintain and update... this was made before that happened... he will not be helping anyone here... most talks and troubleshooting is going to be talked in the main tread
  • Memnoch73 likes this
#17 Memnoch73
  • 5,014 posts
  • Current Device(s):Moto X (2014)
Posted 03 March 2013 - 08:47 PM
Closed. See posted above this for official support thread
Also tagged with one or more of these keywords: ss, safestrap, droid m, razr m, droid razr m
