If I choose to install this, but decide I want to revert back to ics to take the official ota, can I use Matts toolkit to do it?
Yes.
Sent from my RAZR MAXX HD
Posted 02 December 2012 - 07:20 AM
Posted 02 December 2012 - 08:16 AM
Posted 02 December 2012 - 08:50 AM
Posted 02 December 2012 - 09:32 AM
Posted 02 December 2012 - 02:14 PM
Try this method:I went through the update and it was mostly a success, but i wasn't able to regain root. i used OTA Rootkeeper to protect root, updated the binaries (before protecting su) and tried to restore root after the update. Rootkeeper said that it restored su, but it didn't work. (i tried two different apps and they weren't able to acquire root access).
Posted 02 December 2012 - 02:19 PM
I have frozen a lot of junk/bloat with TiBU (IE: i either did the disable in the apps list or frozen with tibu. nothing has been forcefully removed). If I go through all those frozen apps and thaw them out, will i be fine? If the sideload of the update fails, will I just be left at where i am with ICS or does it brick the phone?
Posted 02 December 2012 - 03:01 PM
Posted 02 December 2012 - 03:07 PM
To install the Jellybean OTA on the DROID RAZR HD (Verizon) you must be on System Version 0.7.2.XT926.Verizon.en.USim attempting to help a friend of mine get his hd on this so he doesnt have to wait for the ota. his build number is 7.7 1q144 vqw s334252 2. Is this the correct build he needs to to flash this?
Posted 02 December 2012 - 04:08 PM
your a good man Sir. Thanks for the assistance in chat:)
The MotoCast app creates a private cloud that lets you stream music, photos, and videos from your computer to your smartphone .
See Below for full story and video demo
Posted 02 December 2012 - 04:30 PM
Try this method:
Exit terminal & reboot.
Download Android Terminal Emulator for free from the market.
Enter the following commands EXACTLY as you see them listed here:
If not...
Let me know how those go...
Posted 02 December 2012 - 04:55 PM
Posted 02 December 2012 - 05:02 PM
Posted 02 December 2012 - 05:04 PM
Posted 02 December 2012 - 05:12 PM
Posted 02 December 2012 - 06:29 PM
@Rhubarb Did you temp unroot before install?
Sent from my DROID RAZR HD
I *think* you will need to start over.Be sure to grant SU access and update binaries and temp unroot each time.
Posted 02 December 2012 - 06:34 PM
Temp unroot is not necessary for modern motorola devices.
Posted 02 December 2012 - 06:59 PM
Posted 02 December 2012 - 07:01 PM
Posted 03 December 2012 - 12:33 AM
Posted 03 December 2012 - 06:54 AM
it may be worth pointing out that if you don't temp unroot, you will likely be unable to restore root. I am fairly sure I have seen several reports of this....and also I have tested this theory myself (not necessarily on purpose, but hey, I did test it, lol) and found that without temp unroot, I was not able to restore root. I went back and started over, and temp unrooted...and everything went smoothly
oh...also, you don't need to root until after you take the 0.7.2 OTA (or whatever the version # is, haha!) no need to spend time rooting it when you first go back to stock
