JB Roms?
Posted 12 December 2012 - 04:29 AM
Sent from my Droid Razr Maxx using Tapatalk2.
Posted 12 December 2012 - 06:55 AM
Sent from Razr Maxx running Full Throttle Killer Bean
Posted 12 December 2012 - 07:03 AM
Sent from my DROID RAZR
68.81KB 6 downloads
Posted 12 December 2012 - 02:53 PM
You can use One More Clock "OMC" from the play store. Works on any Rom and any launcher. Here's my setup.
68.81KB 6 downloads
What launcher is that?
Posted 12 December 2012 - 07:34 PM
Looks like Apex. That's what I use, and they look similar.
Posted 12 December 2012 - 07:54 PM
Posted 13 December 2012 - 06:00 AM
what are the widgets with the battery and signal info?Yep, it's apex. I run the same setup on Full Throttle AOKP, Eclipse and Cm10.1
Posted 13 December 2012 - 08:21 AM
I have tried onemoreclock but I like the functionality of circle widget. I like my texts and missed calls showing up in it. I like how I can flip the weather to get different cities. To me, the actual razr widget looks and feels so much better than onemoreclock.You can use One More Clock "OMC" from the play store. Works on any Rom and any launcher. Here's my setup.
68.81KB 6 downloads
Posted 13 December 2012 - 10:39 PM
Looks like the System Tuner (Pro) widgets. I think..what are the widgets with the battery and signal info?
Posted 14 December 2012 - 09:32 PM
Posted 14 December 2012 - 09:35 PM
That's what I wanted to know. I am currently running Droid HD 1.2 now and it does have the circle widget and I love it. Can you post some screens of yours? Also where did you get the Razr HD launcher?I have installed the most recent Wizzed Bean CNVI 4.1.2 JB Rom and installed the Razr HD launcher, which includes the fully functioning circles widget and everything works perfectly. I believe that you can do this with any JB Rom. There is however, an ICS rom (DroidHD) that is based off of the Razr M and Razr HD phones that comes pre-installed with fully functioning circles widget and launcher.
- Jackson1536 likes this
Posted 14 December 2012 - 10:08 PM
Here you go. I like to switch between the default (TouchWiz) launcher which is loaded with the Wizzed Bean Rom, which is similar to the GS3 and the Razr M Launcher. I use the Launcher Switcher app from the Play Store. The Launcher is the same as in the Droid HD Rom, but this rom obviously has the perks of Jelly Bean with some added Samsung apps and fully functioning Google Now!That's what I wanted to know. I am currently running Droid HD 1.2 now and it does have the circle widget and I love it. Can you post some screens of yours? Also where did you get the Razr HD launcher?
Posted 14 December 2012 - 10:14 PM
Has the Jelly Bean lock screen too! This rom has allows you to customize the lock screen and notification bar.Here you go. I like to switch between the default (TouchWiz) launcher which is loaded with the Wizzed Bean Rom, which is similar to the GS3 and the Razr M Launcher. I use the Launcher Switcher app from the Play Store. The Launcher is the same as in the Droid HD Rom, but this rom obviously has the perks of Jelly Bean with some added Samsung apps and fully functioning Google Now!
Posted 15 December 2012 - 08:59 AM
Posted 16 December 2012 - 03:42 PM
Posted 16 December 2012 - 03:59 PM
