XT926 reboots to FastBoot mode
XT926 FastBoot reboot
10 replies to this topic
#1 johnnysyeah
johnnysyeah
  • 59 posts
Posted 26 December 2014 - 09:46 AM
Hey all,
Recently I used RSD Lite to get my XT926 device back to 183.46.10. Since then, whenever my phone is rebooted, it keeps automatically going into FastBoot mode. And this dialog shows up: "Fastboot Reason: Sticky bit factory_fastboot."
Anyone know what it is I had done and if I can turn this off?
P.S. I'm actually gonna do the update to get to 183.46.15 but I'm unable to because when my phone reboots to apply the update, it goes to Fastboot mode.
Thanks in advanced!
- John
  • karlsdroids likes this
#2 livinginkaos
Posted 26 December 2014 - 10:07 AM
In fastboot, connect to your PC and open a command window in your fastboot folder. Type the following: Fastboot OEM fb_mode_set Fastboot OEM fb_mode_clear Fastboot reboot Should boot normal sent from my N6
  • johnnysyeah likes this
#3 johnnysyeah
johnnysyeah
  • 59 posts
Posted 26 December 2014 - 10:46 AM
Thank you! I'll give this a try when I'm off work.
#4 johnnysyeah
johnnysyeah
  • 59 posts
Posted 09 January 2015 - 12:02 AM
Tried this a couple times but no luck... I'm using Minimal ADB and Fastboot. Does that make any difference?
#5 cmh714
Posted 09 January 2015 - 07:27 AM
Shouldnt, you just need fastboot.exe assuming windows.
#6 johnnysyeah
johnnysyeah
  • 59 posts
Posted 09 January 2015 - 09:00 AM
Fastboot reboot
I tried entering that into 3 different commands. Not sure what I'm doing wrong...
#7 johnthehillbilly
Posted 09 January 2015 - 09:12 AM
What is your terminal (command window) showing when you enter the commands ?
#8 ka3boosh
ka3boosh
  • 33 posts
  • LocationCalifornia
  • Current Device(s):Droid Razr XT926 HD
Posted 09 January 2015 - 02:28 PM
it happen to me twice first time the first 2 command fix it the second time i use all the command plus wipe user data
1. adb reboot bootloader
2.fastboot oem fb_mode_set
3.fastboot oem fb_mode_clear
3.fastboot erase userdata
4.fastboot erase cache
5.fastboot reboot
this fix the problem
#9 johnnysyeah
johnnysyeah
  • 59 posts
Posted 12 January 2015 - 04:50 PM
Thanks you guys! ka3boosh's method worked like a charm.
#10 ka3boosh
ka3boosh
  • 33 posts
Posted 12 January 2015 - 09:28 PM
you welcome
#11 karlsdroids
karlsdroids
  • 13 posts
  • Current Device(s):XT926M, XT894, A956
Posted 14 January 2015 - 08:39 PM
O.o- you say "back" to .10, did you downgrade by flashing .10fxz?
