Unlock Droid Razr Maxx Verizon To Use On Gsm
Maxx verizon gsm
22 replies to this topic
#1 Elooije
Elooije
Posted 30 January 2012 - 03:06 PM
Dear all, im new here and not yet familiar with ROM,s... Please could you explain if a new ROM would make it possible to use a verizon droid razr maxx as a gsm phone? It has the antenna, right?
Or are there other ways to get a razr maxx working in europe without waiting or verizon subscription?
Thanks!
#2 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 30 January 2012 - 03:59 PM
No, there is no way to make a CDMA phone work with GSM.
There was just someone last night in the chat from Sri Lanka that bought a CDMA Razr on eBay or Amazon and was asking the same question.
Poor guy has a $750 paper weight.
:-D :-D
#3 Elooije
Elooije
Posted 30 January 2012 - 11:46 PM
Mhh that doest sound good, though it says any razr, also tehe verizon ones, have a gsm antenna. Even mentioned in fcc reports..
#4 Cruiserdude
Cruiserdude
  • 49 posts
  • Twitter:@andrewblitch
Posted 31 January 2012 - 06:43 AM
LTE is a GSM based technology, so all the Verizon LTE devices have a GSM antenna of sorts. People have speculated about the possibility of making some of these phones work on international GSM networks, especially the Rezound and RAZR. However, to my knowledge there has been no serious effort here, or even any indication that this would be possible. Even if the hardware is there, its still a different configuration than the international version, and would almost certainly require a custom kernel, as well as custom radio firmware. The former can't happen unless we can unlock our bootloader, and the latter is extremely difficult. Making the radio firmware requires a very high degree of technical skill, and would also require access to engineering data for the hardware, as well as Verizon's network infrastructure.
Maybe it is possible, and if so, maybe its easier than I make it sound, but I doubt it. I really wouldn't count on it, and certainly not anytime soon. I'm sure they'll have an international version of the RAZR MAXX, maybe even with the 720p screen, before too long.
#5 YourGod
YourGod
Posted 02 February 2012 - 01:17 AM
there must be a way to achieve this.... the reason I am saying that is I have a GSM razr.. I didnt notice that the IC3Razr rom was CDMA only and flashed it to my phone...It booted perfectly and ran fine but, my phone thought it was a CDMA device info even stated xt912. Because of this I could not connect to my GSM network the weird part was I could would still receive SMS messages while loaded but couldn't send anything. This could be just a newbie ideal ( I have no dev knowledge at all) but wouldn't that mean all the CDMA/GSM information is stored within the ROM software now if this is the case you should be able to switch from GSM to CDMA with different ROMS. Please correct me if I am wrong as this is just my observation of the situation. hmmm....
#6 vash_h
vash_h
  • 151 posts
  • Google+:chiayx
  • LocationMalaysia
Posted 02 February 2012 - 02:22 AM
Since the Sri Lankan has a paper weight, no harm trying.
Sent from my Motorola Razr XT910
Running Rooted Motorola Droid XT910 on 65.1.21.XT910.PSHAsiaRetail.en.03
#7 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
  • LocationSchaumburg, IL
Posted 02 February 2012 - 07:33 AM
The radios are different in the phones. The actual hardware chips. You cannot make a phone that's manufactured to only work on LTE also work on normal GSM bands. They're on completely different spectrums. In layman terms, they don't speak the same language. The rezound however seems to be a little unique. But as this isn't an HTC forum I'll leave that explanation out.
#8 javed91214
javed91214
  • 10 posts
  • Google+:javed91214
Posted 16 February 2012 - 07:59 AM
hi ,
i am from india. i flash verizon razr to indian cdma network by using cdma workshop.
when i insert GSM sim on the sim slot , network icon showing cross sighn.
i also searching GSM connectivity for vrizon razr.
acordng to FCC report its possible.
#9 thamm
thamm
Posted 31 May 2012 - 08:39 AM
I talked with motorola support and they claim the hardware in the two devices is exactly the same. The only difference is software.
#10 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 31 May 2012 - 08:51 AM
Isn't moto releasing ics with gsm compatibility? It is possible, just extremely hard.
#11 g35nightrider
g35nightrider
Posted 23 July 2012 - 01:33 AM
<p>Ok, so I looked all over the web for this and let me all tell you the facts because I have a Motorola RAZR and basically I updated to Ice Cream Sandwich, aka Android 4.0 and this DOES WORK ON A GSM network. <img alt=":wub:" class="bbc_emoticon" src="
title=":wub:" /></p>
<p> </p>
<p>I called Verizon to get an unlock code and by default the phone isn't locked. Verizon advised me that the phone was already unlocked. So I went about my travels and went to Greece and London and all the pre-paid cards were working fine. All I had to put in was the pre-paid SIM card unlock code, not the phone's. </p>
<p> </p>
<p>THIS PHONE HAS A GSM AND CDMA compatible CHIP!!! Don't let anyone tell you otherwise. Enjoy all!!<img alt=":)" class="bbc_emoticon" src="
title=":)" /> </p>
<p> </p>
#12 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 23 July 2012 - 06:20 AM
Way to bring this thread back from the grave. Since it was created we've found that the phone does in fact have normal GSM radios in it but were dormant through GB. They were switched on with the release of 4.0.4 ICS. There are many other threads that're more recent that have more information regarding this but suffice it to say that yes the GSM radios are there, they are active in ICS, the phone does not need to be unlocked as it already is but the phone is firmware locked to not accept any US based SIM at this time (ATT/TMO USA).
#13 knghts50
knghts50
  • 199 posts
  • Google+:kevin.page3
  • LocationCopperas Cove, TX (Fort Hood)
Posted 23 July 2012 - 09:27 AM
Arcane quick question then kill this thread. But lets say if i go overseas do i have to get the mobile apn info to use the data towers or was that mixed in 4.0.4. And is it only prepaid sim or can i use contract sims?
#14 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 23 July 2012 - 11:25 AM
As far as I am aware you can use any non-US SIM you want. Prepaid or otherwise. I personally can't test as I haven't left the country in a while but that's what I've been told. As far as data, it's going to depend on the provider. Many of them will auto-pull. Some will require manual config. Unfortunately, there's no blanket answer there. (Example: Tmobile USA didn't used to pull auto-apn info but ATT did. Not sure if that's still true or not but that's how it was for a long time. This obviously doesn't pertain to the razr but that's how it was on my blackberry years ago).
#15 RussianNinja
RussianNinja
Posted 13 September 2012 - 07:30 AM
What about a straight talk sim? It's not exactly US but it uses att towers
#16 ddino2000
ddino2000
  • Current Device(s):Razr Maxx
Posted 12 May 2013 - 08:31 PM
A friend gave me a Razr Maxx that he set up for use with Straight Talk. It worked great until I broke the phone :(   I don't know what he did but I"m sending a new one to him hoping he can do it again :)
#17 Streetwise
Streetwise
Posted 24 June 2013 - 09:01 AM
I too am curious about this.... I have both a Razr Maxx, and Razr M that I'd like to discontinue my Verizon contract for.
I just got off the phone with Straight Talk to explain what I want to do, and the gentleman assured me that Straight Talk will work with my Verizon devices... I told him that I thought that CDMA devices will not run on a GSM network, but he again told me that I can use my existing Verizon handsets with Straight Talk. All I need to do is to purchase the ST plan (from Walmart), call Verizon to get the Access Code, and then contact ST for the conversion. He did say that I may need to purchase a sim card (from Walmart) that will allow for 4G.
I'm not sure I'm buying what he is saying to be true... My biggest fear is to try to convert, having it fail, and not being able to go back to Verizon. It involves a $190 contract termination fee, so I'd hate to pay that only to not have it work. Does anyone know if in the process, I can get the phone working first with ST before I go and terminate the contract?
Dave
#18 Streetwise
Streetwise
Posted 24 June 2013 - 09:21 AM
Just found this.... Maybe the guy was right?
UPDATE: I went to the link and put in my Phone's MEID/Serial Number, and it says "Invalid" This program will not work with 4G LTE technology phones. Hmmm....
#19 robocuff
robocuff
  • 415 posts
Posted 24 June 2013 - 04:51 PM
Might be but I noticed this in the list of reasons to switch.
  • Keep 4G speeds when bringing a 4G T-Mobile compatible device
What does that mean for Verizon 4G devices?  Are they T-Mobile compatible?  I don't know.
#20 twolostminds
twolostminds
Posted 25 June 2013 - 05:13 AM
Just out of curiosity what happens if you just pop an activated StraightTalk SIM into the XT912 Razr Maxx and set the phone to GSM or Global?
