How to enable safe systems on safestrap 3.11
bcamps21685
, Jan 16 2013 06:24 PM
4 replies to this topic
Posted 16 January 2013 - 06:24 PM
when I boot into safe strap it says disabled how do I enable it
BC
Posted 16 January 2013 - 06:29 PM
In the menu, you should see Boot Options. Select that and create a ROM slot. After you create a ROM Slot, Activate it (it might activate automatically after you create I believe). If you're new ROM slot1-4 is active, Safe System will be Enabled.
If you go back and activate your Stock ROM slot, it will say Disabled.
Posted 16 January 2013 - 06:30 PM
That's because you are on the unsafe side. Press boot options then create a ROM slot. 1 gig data partition should do to get you started out. Make sure you have a ROM on your sdcard ready to flash. Wipe data and cache and all that jazz then install the ROM and reboot and .......profit.
- Monkeh likes this
Posted 05 August 2013 - 05:21 AM
Every time I try to flash a ROM in ROM Slot 1, I keep getting an error saying "error flashing zip '/external_sd/ROMs/xxxxxx (name of ROM). I guess I'm just kinda confused, because I wiped cache/data and all that, and I'm still getting nowhere. Any ideas?
Posted 18 August 2013 - 12:54 PM
Moving to Droid Razr General [XT912] - {Q&A, Discussion} - Reason Non-Emergency
