Can barely hear earpiece on Maxx
Posted 05 February 2013 - 06:40 AM
This space for rent
Posted 05 February 2013 - 06:43 AM
Also, Moving to --- > Droid Razr General [XT912] Reason Non-'Emergency' situation
Posted 05 February 2013 - 07:03 AM
This space for rent
Posted 05 February 2013 - 07:06 AM
Yes, I'm constantly hitting the volume up button during phone calls hoping that i inadvertently turned it down. Sorry for posting in the wrong area...
This space for rent
Oh its ok, No big deal really, just organizing a bit.. 2 second click
Hmmmm, Did this happen suddenly? Can you think of anything you may have installed that might have caused this issue? Are you using Something like Beats Audio, like an EQ?
Are you positive you changed your batteries on your hearing aid lol
Posted 05 February 2013 - 07:13 AM
This space for rent
Posted 05 February 2013 - 07:25 AM
Naa, it's really been a problem since I had it...just never thought to post about it. I love the phone overall, just wish i could hear people on it a tad bit better. And yes, i replaced the batteries in my hearing aid just last week...
This space for rent
Honestly it could be a hardware issue, otherwise I would try and reload everything, using unbrick etc
Posted 05 February 2013 - 07:27 AM
This space for rent
Posted 05 February 2013 - 07:28 AM
Alright, I'll look into that...thanks bud!
This space for rent
Swing into How To's or click here
Posted 05 February 2013 - 07:58 AM
Posted 05 February 2013 - 08:38 AM
Edit...checked it, it's up all the way...still not very loud...it might just be something i either have to live with or new phone time...
This space for rent
Posted 05 February 2013 - 06:49 PM
This space for rent
Posted 06 February 2013 - 07:29 AM
- Maxximized likes this
Posted 06 February 2013 - 08:01 AM
Posted 06 February 2013 - 08:05 AM
Try adding ro.config.vc_call_vol_steps=10 at the bottom of your build.prop. The default is =7. Open script manager, navigate to /system, press menu,advanced,mount system as rw. Then open build.prop,when prompted I chose rb text editor and then add the line mentioned above. This is tinkering with system files so be sure to take all necessary precautions beforehand nandroid backup etc.I thought it made a difference on my razr but since I had no way of doing a side by side comparison it may just be a placebo effect but definetly worth a shot.Good Luck!
Thanks bud, I'm gonna try this!
This space for rent
Posted 06 February 2013 - 08:17 AM
Edit, found my answer. Guess this is just one more reason to root.
This space for rent
Posted 06 February 2013 - 08:20 AM
Posted 06 February 2013 - 09:26 AM
This space for rent
Posted 06 February 2013 - 10:58 AM
Posted 07 February 2013 - 04:32 AM
But i didn't know enough about root to know what i was doing while it was rooted. I mean, i was like a kid with a lifted truck who had never left the pavement...knew i had something cool, but had no idea what it was capable of or what to do with it. I still really don't, just gotta do more reading and see if i can dive off into it better prepared this time.
This space for rent
Posted 07 February 2013 - 04:57 AM
