Hello everyone I've been a member of this forum for a while I don't post much because I like to search, read, and figure stuff out on my own. But I have learnt so much from this forum so I just want to start out saying thank you to all the staff and devs I hope y'all enjoy my first contribution to the forum!
I don't know if anybody wants this or not but I thought I would share it since I know some people stay on the stock odex rom. I've been working on my own rom for a long time slowly making it what I want and have been wanting to make it odex based. So I knew if I could get the 1% Battery and Pull down toggles to work in odex form, then I can get my whole rom to odex format. The base of the mod started from halo13's Evolution 1.5 rom I took his SystemUI.apk and Services.jar, I then changed the battery images and some other images to aosp so I want to thank halo13 for his rom. I also want to thank alteredlikeness on xda for his .211 odex mod/guide and his reodexer tool. I will also post the deodexed form of the mod for people on the stock deodex rom to enjoy.
One last thing I've only tested this on my phone and I'm using JB Dual Boot it should work on the ota though.
Disclaimer you are responsible for the stuff you do to your phone, I take no responsibility if you break it!
Installation:
Boot into Safestrap (v3.11 that's what I'm on will probably work on older versions)
You need to be on a stock based rom in a Rom Slot
Install Zip
Wipe cache/dalvik cache
Reboot
Enjoy!
Update for the 98.72.16 OTA
I've updated this mod to the new OTA files the pulldown toggles are different in these I ported over and changed one toggle of the .211 toggles, that I think that were done by nitro so I want to thank him for the original toggles. Everything else is the same I used the same images for the battery icons only thing I did was port to the .16 base I don't remember who posted the deodexed version but thank you. Also want to thank alteredlikeness again for his guide for the services.jar and reodexer utility.
(3/18/2013) Update: Fixed the GPS toggle and Data toggle force closing
Downloads:
Stock .16 Odex 1% Battery and Pull Down Toggles
Stock .16 Deodex 1% Battery and Pull Down Toggles
Stock .16 Odex 1% Battery Mod only
Stock .16 Deodex 1% Battery Mod only
Back to Stock Undo zips:
Stock .16 Odex Back to Stock Battery/Undo
Stock .16 Deodex Back to Stock Battery/Undo
98.72.8 Christmas Leak files ONLY flash if your on the leak!
Downloads:
Stock Odex 1% Battery and Pull Down Toggles
Stock Deodex 1% Battery and Pull Down Toggles
Stock Odex 1% Battery Mod only
Stock Deodex 1% Battery Mod only
Stock Odex Back to Stock Battery/Undo
Stock Deodex Back to Stock Battery/Undo
