[ROM] INFLIKTED HD for DROID RAZR HD XT926 - V2.0 (03/20/2013)
#101
Posted 23 March 2013 - 12:49 PM
What's going on?
#102
Posted 23 March 2013 - 01:31 PM
#103
Posted 25 March 2013 - 01:59 PM
#104
Posted 25 March 2013 - 05:47 PM
im using the one from market. Its called wifi tether for root usersGreat rom.. Outstading battery life.. I'm curious if anyone else has had a problem getting their hotspot to activate on here. I tried to do it today and had no luck on getting it to turn on. Any help guys?
#105
Posted 26 March 2013 - 06:09 AM
I was using that as well but it's not anywhere near as nice as the stock tether. I also had the same problem he described as I posted about it right before him.
If this ROM is anything like Hash's 10.1 when the revision comes out (in terms of speed and working tether, not 4.2.2) then I'm sold.
#106
Posted 01 April 2013 - 06:51 AM
#107
Posted 02 April 2013 - 09:42 AM
Sent from my INFLIKTED HD MAXX...
#108
Posted 03 April 2013 - 03:18 AM
#109
Posted 04 April 2013 - 04:29 PM
#111
Posted 05 April 2013 - 01:03 AM
i think it is said you can flash 4.1.1 based roms on to 4.1.2 but make sure to be using a rom slot on ss i dont think downgrading on a rom stock would end well lol
I have dev edition with TWRP...so could just flash the ROM?
Edit: Yep justed flashed the ROM. it was a little wonky on setting up. Google Play kept crashing. Seems okay so far. Wonder how it will compare battery life wise and smotthness to the stock 4.1.2
#112
Posted 06 April 2013 - 06:58 AM
#113
Posted 08 April 2013 - 05:41 PM
Don't know if the flash didn't take well or backing up to 4.1.1 from stock 4.1.2 if the culprit but got a lot of lag and my phone froze. Had to simulate battery pull and reflash 4.1.2 firmware
It was a bad flash. Running Inflikted again and its top notch.
#114
Posted 09 April 2013 - 04:37 PM
Or how you have to install?
#115
Posted 09 April 2013 - 04:39 PM
can be installed TWRP fails me
Mount system in recovery. See if that works
#116
Posted 09 April 2013 - 04:47 PM
#117
Posted 09 April 2013 - 04:48 PM
Any other ideas I have no backup: (
Did you backup
#118
Posted 09 April 2013 - 04:51 PM
For example the room [DEV-EDITION] [ROM-AOSP] Unofficial CM10.1 (JB 4.2.1) [01/24: BETA] works well only me that is not stable yet.
thanks
#119
Posted 09 April 2013 - 04:53 PM
Do not back up because I thought that it works correctly
thanks
Browse around the site. Someone did the same thing
#120
Posted 09 April 2013 - 05:00 PM
Ok so I checked the entitlement option and it was still set to "1"... I thought this had been fixed in the rom? Anyway, reset to 0, rebooted, and now the service tries to start but immediately shuts down after starting.
What's going on?
Wi-Fi Tether from the Market DOES work . It has to be configured correctly. I am using it now.
Device Profile - Generic ICS/JB (wlan0)
Enable Wi-Fi Encryption (check)
Wi-Fi driver reload (check)
Enable Access Control (check)
Routing Fix (check)
That should work, those are my settings.
Also tagged with one or more of these keywords: Razr HD, XT926
