How To Install Ics 6.14.79 [It's Fastbootable Back To Gingerbread!]
Posted 15 May 2012 - 11:14 AM
Posted 15 May 2012 - 11:19 AM
Posted 15 May 2012 - 11:22 AM
Posted 15 May 2012 - 11:33 AM
No.No way to sideload over 84?
Its never than 6.14.75 and it can be fastbooted back. Shouldn't matter the age compared to those if you get stuck on them.Please don't bash me, but just so I'm clear...6.14.79 is an even newer version than 6.14.84/.85?
Posted 15 May 2012 - 11:43 AM
- tonyo50138 likes this
Posted 15 May 2012 - 11:58 AM
When you're considering a leak.. there isn't any changelog. You have to do all the testing yourself and feel the difference between roms.What is the change log of. 79 over.75?
Hey matt.. have you tried Fastbooting from 85 to 181 with your utility (I know it won't work but...) after brute force you can still side load this 79... a way to get us off the 84/85... Whatever happened to "Savior of the Razors"?
Posted 15 May 2012 - 12:11 PM
Posted 15 May 2012 - 12:20 PM
Posted 15 May 2012 - 12:24 PM
Posted 15 May 2012 - 12:25 PM
When you do that can you post here if fastboot to 181 worked for you?Matt, Why u got no data in that there pic? Your batmobile using it all up again? I'll be a flashing back to .181 so I can give it a test here in a bit.
Founder and main developer of Team SpeedCore
- DarkOverDroid likes this
Posted 15 May 2012 - 12:41 PM
What's the bootloader version of this one?
- ralphie0108 likes this
Posted 15 May 2012 - 01:00 PM
incoming calls and keep vibrating), but aside from that it's been pretty stable.
Edit: can you flash back to .181 with RSD lite as well, or do you HAVE to use Droid Razr Util 1.6?
- Picaso86 likes this
Posted 15 May 2012 - 01:13 PM
Thx for the post dude
[ Courtesy of Hotel California ]
Posted 15 May 2012 - 01:17 PM
Posted 15 May 2012 - 01:49 PM
.75 kernel: 3.0.8-g6f89f34 hudsoncm@il93lnxdroid53 #1
.79 kernel: 3.0.8-ge5a0f66 hudsoncm@il93lnxdroid52 #1
.84/.85 kernel: 3.0.8-gc895fbe hudsoncm@il93lnxdroid52 #1
Same webtop (wt-3.0.0-beta)
.75 Build date: Sun Mar 25 07:22:36 CDT 2012
.79 Build date: Thu Apr 12 00:09:53 CDT 2012
.84 Build date: Thu Apr 26 00:34:22 CDT 2012
.85 Build date: Fri Apr 27 00:32:32 CDW 2012
.75 Baseband (radio): CDMA_N_04.16.00R LTEDC_U_08.17.00
.79 Baseband (radio): CDMA_N_04.17.00R LTEDC_U_08.17.00
.84 Baseband (radio): CDMA_N_04.19.00R LTEDC_U_08.17.00
.85 Baseband (radio): CDMA_N_04.19.00R LTEDC_U_08.17.00 (same as .84)
.75 Build number: 6.7.1-68_DHD-15_M4-7
.79 Build number: 6.7.1-68_DHD-15_M4-11
.84 Build number: 6.7.1-68_DHD-15_M4-16
.85 Build number: 6.7.1-68_DHD-15_M4-17
I'm in the process of dissecting the update.zip to see what else is in there...
** thx to Jimmy8881 for the .75 info and phatdaddyz01 for the .85 info **
- mattlgroff, DarkOverDroid and quangtran1 like this
Posted 15 May 2012 - 01:53 PM
Posted 15 May 2012 - 02:04 PM
Posted 15 May 2012 - 02:09 PM
Thanks base.For those wondering:
.85 Build date: No idea but you can search
.85 Baseband (radio): No idea
.85 Build number: Once again, no idea
