[Script/Utility] ROOT RAZR HD XT926 For LOCKED Devices On 9.18.79
Root fix root exploit Droid Razr HD Root Locked Bootloader root exploit root 9.18.79 root 9.20.1 utility
628 replies to this topic
#1 tucstwo
  • Google+:tucstwo@gmail.com
Posted 23 July 2013 - 10:05 PM
There is no current root method for 9.30.1
MAJOR EDIT done by SamuriHL
IF YOU DO NOT READ THIS FULLY, WHEN YOU BRICK YOU ARE ON YOUR OWN
Those that can follow directions will not need a link to Motochopper 1.3, which no longer exists.  Get the original Motochopper from here:
Now, if you are on 9.18.79 (or 9.20.1 as it might show), you can follow these directions:
REQUIREMENTS:
Google for "motorola usb driver" and install it.
DIRECTIONS:
o) Get this:
o) Extract the boot.img from it
o) Flash the boot image using AP Fastboot mode: fastboot flash boot boot.img
o) Reboot and run motochopper
o) Get this:
o) Reboot and you are done
WARNINGS:
o) If you are on any other build than 9.18.79 (or 9.20.1), following the above directions *WILL BRICK YOUR PHONE*.
o) If you are not able to follow the directions above, DO NOT USE THIS ROOT METHOD UNTIL YOU CAN.  That does not mean asking for step by step instructions.  It means GO READ AND LEARN BEFORE DOING.
credits:
DJRBliss for Motochopper
for the updated Motochopper
for the updated Mac/Linux script
for adding the system img flashing lines
Much thanks to
for connecting me to
 devised by
  • CellZealot, lownslow200sx, MahoVader and 18 others like this
#2 tucstwo
Posted 23 July 2013 - 10:09 PM
Ok, test time friends. Let's give it a go and I will change/update the OP as needed! Thank you all! Now let's help those who lost root!
  • johnthehillbilly, Jermide, gemro311 and 1 other like this
#3 tucstwo
Posted 23 July 2013 - 10:13 PM
Post 3...
This is beta, I'm not ironed out any problems, PLEASE post specifics so this method can be repaired thoroughly if need-be!
Also added credits to
and
for their contributions to this solution.
#4 SamuriHL
  • 43,456 posts
Posted 24 July 2013 - 03:00 AM
Tucs you gotta add the mr2 fxz link. My rsd script needs to get added to the unzipped mr2 fxz directory. Then they can flash it. Also I'd add a step to ensure the su binary is updated before they protect root with voodoo. Otherwise this looks great!
Sent from my Xoom using Tapatalk 4 Beta
#5 Pearlmikejam
Pearlmikejam
  • 14 posts
Posted 24 July 2013 - 04:18 AM
FWIW, another option, for folks who do not mind going through a full wipe, is to use Matt's Utility to downgrade to 9.16.6 update and root.  You can then protect root, accept the update and restore root.  I have done this twice on my Maxx HD.
  • ut3jaw likes this
#6 tucstwo
Posted 24 July 2013 - 04:19 AM
It should be zipped up in there? Did I mess something up?
#7 SamuriHL
  • 43,456 posts
Posted 24 July 2013 - 04:45 AM
Yes, you missed the fact that i only provide the xml script, not the full MR2 FXZ.  My xml file needs to be extracted into the extracted MR2 FXZ directory.  Then in RSD they flash with my script not the one that comes with the FXZ.  So we need to provide this link for them and to explain to extract the files to a directory, then extract my file into it.
So extract those files, then extract the SamuriHL_Downgrade.zip into the same folder, then select the SamuriHL_Downgrade.xml in RSD to flash it.  This will downgrade to MR2 while keeping data.
  • anyonebutme likes this
#8 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 24 July 2013 - 04:49 AM
Is it possible to whip one of these up for the RAZR M owners. Also looks good Tucs. Atta boy ;)
sig made by
Rinkle McBally
#9 SamuriHL
  • 43,456 posts
Posted 24 July 2013 - 04:51 AM
Same process, different FXZ.  I can see if my RSD script is "universal" between the M and HD.  I'm not sure when I'll get a chance to do so.  If you can post the XML from a working FXZ it'd speed things up.
#10 tucstwo
Posted 24 July 2013 - 05:19 AM
Oh no Sam, I packaged your xml up into a zip including the files. It's all there.
#11 SamuriHL
  • 43,456 posts
Posted 24 July 2013 - 05:26 AM
Oh I see.  Neat.  Ok then we're good.
#12 SamuriHL
  • 43,456 posts
Posted 24 July 2013 - 05:27 AM
Wait, where's the download link for it then?
#13 tucstwo
Posted 24 July 2013 - 05:31 AM
It says up top under stuff you need "SamuriHLs downgrade xml.zip
That's the script and the files which I packaged together
#14 SamuriHL
  • 43,456 posts
Posted 24 July 2013 - 05:32 AM
You mean that link to my user profile?  LOL
's "Downgrade.xml.zip" You will need this to roll back!
That's not gonna get them so far.  ;)
#15 tucstwo
Posted 24 July 2013 - 05:36 AM
Don't click your name, click the words downgrade . xml.zip
I'll change it to make it easier when I get in front of my pc.
  • cyco1 likes this
#16 SamuriHL
  • 43,456 posts
Posted 24 July 2013 - 05:45 AM
You do know I'm not an idjit right?  The link is broken. That's what i'm saying.  No link there.
  • livinginkaos likes this
#17 CellZealot
CellZealot
  • 24 posts
Posted 24 July 2013 - 06:26 AM
Good job guys! You will get the kinks worked out soon I am sure, but this looks pretty good.
Tutorials are hard to write properly and clarity and thoroughness are critical, of course.
Thanks for doing the footwork to lay this all out!
Edit: Here is a link to the edited XML for the VZW_XT907_4.1.2-9.8.1Q-66_1FF RAZR M that should work the same way on that device.
  • tucstwo, SamuriHL and shane1 like this
#18 SamuriHL
  • 43,456 posts
Posted 24 July 2013 - 06:41 AM
We'll get it tweaked out with a few more things added and I think it'll be good to go.
#19 livinginkaos
I put the modified .zip link up - it's live now
  • shane1 likes this
#20 tucstwo
Posted 24 July 2013 - 08:00 AM
Ok, everything is all set now. And thanks for that, CellZealot. I'll whip up another zip file later with everything included for the users.
Also tagged with one or more of these keywords: Root fix, root exploit, Droid Razr HD, Root, Locked Bootloader, root, exploit, root 9.18.79, root 9.20.1, utility
