[Rom-100% Stock] Motoblur 6.16.211 (Official Flashable Odex Ics) For Safestrap
148 replies to this topic
#1 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 16 June 2012 - 01:22 PM
[2012-06-17]: Added Superuser.apk and removed scripts which didn't exist from updater-script (backuptool, finalizerelease)
What is this!?
This is a stock version of MotoBlur 6.16.211 -- setup as a flashable ROM for Safestrap (v2.00)
Why would you want this?
- Chances are you won't use this at all. This is for devs who want to start modding the stock ROM.
- In theory, you can install just the ROM update via Safestrap as each ICS leak hits and not worry about flashing the full OTA. No guarantees that this will continue to be the case tho.
What do I need to have installed to run this?
- You must be on one of the MotoICS leaks for the Droid RAZR (e.g. .79/.85/.2xx)
- Rooted
- Busybox
- Safestrap v2.00 for the ICS Leak
The only changes from stock are:
- I took the liberty of disabling "Qe" which logs all of the differences in the current OS compared to how it comes from Motorola. It's a lag monster on the bootup, and an invasion of privacy.
- Pre-rooted with su binary
- Updated busybox and symlinks in /system/xbin
- Configured for use w/ Safestrap
- Added Superuser.apk (2012-06-17)
md5sum: 8fda3cd6aa2c0b3f47c6e92d84b5aeaf
Enjoy!
Edited by tucstwo, 12 October 2012 - 06:13 PM.
And now a new fresh link. Safer than before
  • cvhovey, andlaw, cynnar and 4 others like this
#2 en7gm4
en7gm4
  • 137 posts
  • Twitter:https://twitter.com/#!/en7gm4
  • LocationtEXas
Posted 16 June 2012 - 01:27 PM
probably dumb question (durrrr...) but just flash this like the regular ics leaks or what.
#3 (TSON)
(TSON)
  • 529 posts
Posted 16 June 2012 - 01:31 PM
Wait...what?! Does it send it anywhere?
#4 Badger50
Badger50
  • 241 posts
  • Google+:badger50@gmail.com
  • LocationKansas City
Posted 16 June 2012 - 02:09 PM
I am assuming that from the top of the OP, this is actually a flashable Rom using the ICS safestrap 2.0 version, without having to go through all the other steps to install the other leaks that have been released. Please correct me if I'm wrong Mr. Hashcode :-)
#5 XCellFoneSalesRep
XCellFoneSalesRep
  • 53 posts
  • Twitter:https://twitter.com/XCellFoneRep
  • Google+:http://goo.gl/XgDaW
  • LocationThe Joisey Shore, Nu Joisey
Posted 16 June 2012 - 02:26 PM
I'zzz waz wunderin when such a zippy wud becum available! Thanx for dis.
*now we can flash *special* CWM zips to stock build* for those whom do kno for why this is valuble :P
#6 Morkai AlMandragon
Morkai AlMandragon
  • 10 posts
Posted 16 June 2012 - 02:34 PM
huge thanks for this!
#7 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 16 June 2012 - 02:37 PM
It is to be used from the 211 leak using SS ICS 2.0
#8 Badger50
Badger50
  • 241 posts
Posted 16 June 2012 - 03:23 PM
Thanks for clearing that up for me Matt. Us old dummies need all the help we can get. Think I'll just wait for the OTA, I can cause less damage to myself that way :-)
#9 uberbdon
uberbdon
  • 367 posts
Posted 16 June 2012 - 03:46 PM
Please kill yourself.
  • W0017roid, bweaver11b, watt9493 and 1 other like this
#10 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
  • Twitter:xlightwaverx
  • LocationEast Coast
  • Current Device(s):XT912, Kindle Fire HD
Posted 16 June 2012 - 04:19 PM
So wait, we can install .79 leak, and run 211 on top of it? What an awesome idea :)
X
#11 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 16 June 2012 - 04:22 PM
X
Let me know how this works. :P
No guarantees, as the kernel for. 79 is pretty far back.
Sent from my DROID4 using Tapatalk 2
#12 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
Posted 16 June 2012 - 04:27 PM
I was telling Matt I had to learn up DSIXDA kitchen so I could make this very same thing. Thanks for this. Hopefully all of us with GB CDT.Bin can finally run the latest leaks and be able to successfully go back. Also, we can fastboot flash the 211 boot.img over a .79 (safestrap 2.0'd) and this (in theory) should be the answer. We should be able to boot with any boot.img I thought.
Unless I am missing something.
X
#13 Brad92
Brad92
  • 624 posts
  • LocationTexas
Posted 16 June 2012 - 04:33 PM
X
Dammit... just flashed to .211... oh well haha
#14 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 16 June 2012 - 04:34 PM
X
I'll be the Guinea pig but will have to wait till tomorrow cause it's beer-thirty and bad things always happen when I mix alcohol and my phone
#15 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
Posted 16 June 2012 - 04:36 PM
"Well Doc, I'm not sure how my phone got lodged up there, but I'd be obliged if you could remove it for me..."
Doc: "**** around it!"
#16 jb_alphamale
jb_alphamale
  • 251 posts
Posted 16 June 2012 - 04:46 PM
I was waiting for this for ages to play with apps and stuff in the stock ROM. God bless you for it.
#17 Guest_BDH_*
Guest_BDH_*
Posted 16 June 2012 - 04:48 PM
Myself and EmericanX should have something soon. Tweaked, debloated and with 1% battery hopefully.
  • jimyv, ddodge68 and fixxxer2012 like this
#18 2tealth
2tealth
    I Cannot Spell Stealth
  • 133 posts
Posted 16 June 2012 - 04:51 PM
X
I aske Matt about flashing a 03 kernel and he said it might not downgrade. Do it at your own risk.
Founder and main developer of Team SpeedCore
#19 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
Posted 16 June 2012 - 04:54 PM
I thought as long as CDT.Bin wasn't flashed the Secure Level in the eFuse didn't change.
#20 phatdaddyz01
phatdaddyz01
  • 288 posts
Posted 16 June 2012 - 04:57 PM
If I'm still on 209 can I install safestrap & flash this on top of it or does it only work if your on 211?
Sent from my PhatMaxx
