Twitter Facebook
[Rom][Alpha] Ic3Razr 01-27-2012
dhacker29 ICS
  • You cannot start a new topic
685 replies to this topic
#1 dhacker29
dhacker29
    CM Master
  • 61 posts
  • Twitter:dhacker29
  • Google+:davidhackerdvm@gmail.com
Posted 25 January 2012 - 11:58 PM
IC3RAZR ALPHA
YOU MUST BE ON THE .748 KERNEL AND RADIO TO FLASH THIS IF YOU ARE ON THE LEAK .173 YOU WILL NEED TO FASTBOOT BACK FIRST
Well here it is ICS for the DROID RAZR alpha build.
A HUGE THANKS TO:
DroidTh3ory for getting me excited about building ROMs to start with!!
AOSP and CyanogenMod for all the hard work on the source
Hashcode for merging the motorola code into framework base and system core and setting up the initial device and vendor trees for sypder, as well as sharing his progress on the DROID 3 with us and letting me hit his GTalk all the time. Without his initial work NONE of this would have been possible.
LiQuIDzGrL for the cool boot animation
Google for giving us Android to play with
ALL DEV's in forums everywhere for giving me the inspiration that I can do this too!!!
All source is available at
DETAILS:
CM 9 ICS_MR1 and AOSP (ICS 4.0.3_r1)
What works:
Gapps are included due to having to be customized since the camera doesn't work
Graphics working smooth (Hashcode)
Touchscreen
Capacitive buttons (Hashcode)
Charging indicator (Hashcode)
BlueTooth
Both SDCards mounting on phone
Builtin Screenshot (CM)
Reboot menu (CM)
Phone and SMS works
GPS fully functional
Audio fully working (Hashcode audio wrapper based on tpruvot's Defy work)
USB mounting of external SDcard (internal will not PC mount)
Gallery recognizes both cards (Hashcode)
1x/3G/LTE data working
NOTE: you may have to dial *#*#4636#*#* (or use Phone Info from the market) and toggle data mode between modes. For me toggling to GSM only for 5 sec, WCDMA prefered for 5sec, then to CDMA only until 1x data connects, and finally to GSM/CDMA (auto prl) and leave it. It may take up to a minute to get 1x and then up to a minute to switch to 3G/LTE
Not working:
ADB
Camera
GTalk due to camera not working (Xabber is included as a substitute)
Market will load and search but will not download apps until you open Term and "su" then type "drmserver&" or
Temp market fix:
load up ROM TOOLBOX (already installed) allow root go to "scripter" create new (top right corner) with custom name (anything, doesnt matter) put this in the script
mount -o remount,rw /system
chmod +x /system/bin/drmserver
/system/bin/drmserver&
mount -o remount,ro /system
save select and set "as boot"
MARKET FIX VIA TERMINAL EMULATOR: OPEN TERMINAL TYPE SU HIT ENTER THEN TYPE DRMSERVER& HIT ENTER AND YOU ARE THRU.
INFORMATION: READ THIS!!!!
This is an alpha build and SafeStrap for the RAZR is the easiest way to test it as you don't loose your main rom, but it also has full support for 2nd init booting in CWR through RAZR Bootstrap.
Don't blame me if screw up your phone Posted Image
INSTALL AND DOWNLOADS
SafeStrap for RAZR:
ROMS:
MD5: cb97c7ccfd1aff4530cbcd12d954bcdf
Read the intro and changelog before asking "Why doesn't this work" Posted Image
INSTALL VIDEO BY DIRTYDROIDX
HOW TO GET DATA ENABLED BY DIRTYDROIDX
SCREENSHOTS
Posted ImagePosted ImagePosted Image
CHANGE LOG
V ALPHA 01-25
First public alpha release.
#2 Erp
Erp
  • 277 posts
Posted 26 January 2012 - 12:04 AM
This is absolutely amazing DHacker. I will flash this as soon as possible!
EDIT: Downloaded, MD5 verified, flashed in SafeStrap. Wiped everything, /system, /data, dalvik, /cache, and currently waiting for it to boot. I've just got a solid black screen at the moment after the SafeStrap menu. Is that normal?
#3 Erp
Erp
  • 277 posts
Posted 26 January 2012 - 12:31 AM
It did seem to flash awfully fast for a 200MB ROM...
Turns out it sat at the black screen for 5 minutes before I decided to reboot it.
#4 mattlgroff
mattlgroff
    The Dark Knight
  • 2,475 posts
  • Twitter:mattlgroff
  • LocationSan Diego,CA
Posted 26 January 2012 - 01:04 AM
Great job on reaching Alpha David, glad to see all your work is going somewhere..and fast! Nice looking thread too :)
#5 orcsbane13
orcsbane13
  • 63 posts
Posted 26 January 2012 - 01:52 AM
Tried flashing a couple of times, I can't get it to fully boot. Gets past the boot animation and says updating android then reboots and loops doing that. Wiped system, data, cache, dalvik. Used safe strap.
Also does it matter if I'm on the 173 leak or do I need to be on the 748?
#6 dhacker29
dhacker29
    CM Master
  • 61 posts
  • Twitter:dhacker29
Posted 26 January 2012 - 02:25 AM
I updated the OP this will ONLY work with the .748 kernel/radio if you are on any other then you have to fastboot back first. Also give it time sometimes the screen stays black for a while on first boot before the boot ani comes up it will take around 5-10 minutes for first boot.
#7 Z28nck33
Z28nck33
  • 22 posts
Posted 26 January 2012 - 03:09 AM
Wait 4g is working?! I also own I bionic does that mean its close too?
#8 detr0yt
detr0yt
  • 86 posts
  • LocationDetroit MI.
Posted 26 January 2012 - 05:09 AM
Omfg! I can't wait to get home from work!
#9 Frogman
Frogman
  • 18 posts
  • LocationSan Diego
  • Current Device(s):Rooted Droid Razr with JB Aviator Rom
Posted 26 January 2012 - 05:32 AM
Leave it to me. I followed video and boot looped. I was using boot strap. I did not do an MD5 sum check. I need to do this from now. on. Boot Looped for 10 min. Able to get into recovery. Working on fixing now. Dunno how it will end. I was on a clean install of 6.11.748 when I did it. :( FACK
#10 benefit14snake
benefit14snake
  • 217 posts
Posted 26 January 2012 - 05:56 AM
Very nice dhacker!!
Sent from my Transformer Prime TF201 using Tapatalk
#11 coloradoflats
coloradoflats
    Willing to Brick for ICS
  • 159 posts
  • Twitter:@KevinVanLear
  • LocationU.S.
Posted 26 January 2012 - 06:03 AM
Again, it is highly recommended to stay on SafeStrap for now (or ever :)) It is a great way to preserve stock incase you need to OTA update.
That being said, I can really vouche for this ROM. Great job DH. I have been running it for a day now solid. Follow the op and do not get discouraged if it locks up and reboots on you a little while after install. I found this to be normal as the ROM takes a little while to settle in, but then runs like a champ. I would recommend backing up your apps to sdcard before you flash. There are also multiple programs that will restore your apps in ICS, just make sure you have THAT particular apk on your sdcard or you will have to download from external sources. Again, give DHacker some love, as he has put in mad time on this entirely of free will and with a cracked screen nonetheless....
Also a shoutout to Eckdawg for making this phone happen for DHacker... that was huge.
"Did you see what I said?"
#12 Z28nck33
Z28nck33
  • 22 posts
Posted 26 January 2012 - 07:00 AM
Try installing the rom then wiping data/cache
#13 DarkestSpawn
DarkestSpawn
    Tester
  • 293 posts
Posted 26 January 2012 - 07:19 AM
Did u wipe system after you flashed? As that would be the cause of no boot. If u did the wipe before it sometimes takes up to 10 mins to boot on the first run.
-Beta Mod-
-Grand Master of the Testing-
#14 arcanexvi
arcanexvi
    Property of Roo
  • 838 posts
  • LocationSchaumburg, IL
Posted 26 January 2012 - 08:00 AM
Glory be the day when this hit alpha instead of pre-alpha :) Fantastic progress so far.
#15 DarkestSpawn
DarkestSpawn
    Tester
  • 293 posts
Posted 26 January 2012 - 08:16 AM
Agreed. Another job well done by the Dev Community involved in this, Especially dhacker29.
-Beta Mod-
#16 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 771 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 26 January 2012 - 08:26 AM
Bg congrats dhacker with this major update to IC3! and to all deving and testing.
Verizon Razr XT912 US Verson. XDA addy: MrFrankFromCM If you wish to buy me a beer send to frank_reyna@hotmail.com THANKS
#17 Erp
Erp
  • 277 posts
Posted 26 January 2012 - 08:35 AM
Thanks for the heads up. I'll be more patient this time! Here we go!
#18 arcanexvi
arcanexvi
    Property of Roo
  • 838 posts
Posted 26 January 2012 - 08:51 AM
Fastboot isn't necessary to downgrade the kernel/radio. All they have to do is install the rollback package if they're on a stock 173 installation. It'll be quicker that way unless they're on a custom ROM based on 173.
#19 Erp
Erp
  • 277 posts
Posted 26 January 2012 - 09:26 AM
My god, this ROM is wonderful. I'm booting back into my main system to backup titanium backup and its license, and all the rest of my apps so I can install them on ICS.
#20 DEMO333
DEMO333
  • 48 posts
Posted 26 January 2012 - 09:45 AM
Demnn u guys r rock my razr thanks. For the hard work :)
#21 RangeOfficer452
RangeOfficer452
  • 42 posts
Posted 26 January 2012 - 10:07 AM
rollback package? where would I find this nifty rollback package?
#22 arcanexvi
arcanexvi
    Property of Roo
  • 838 posts
Posted 26 January 2012 - 10:38 AM
It's in my installation thread for 173. Bear in mind it'll only work if you're running stock 173. If you're on any custom ROM or have jacked around with 173 too much install will fail @ current system verification and require that you fastboot.
Edit:
Edited by arcanexvi, 26 January 2012 - 10:42 AM.
added link
#23 RangeOfficer452
RangeOfficer452
  • 42 posts
Posted 26 January 2012 - 10:46 AM
Awesome! Thanks for quick reply. I know what I'm doing this afternoon instead of patrolling the mean streets of #$@%&+()&%#@.
#24 The Admiral
The Admiral
  • 21 posts
  • Twitter:sthorderson
  • LocationSL,UT
Posted 26 January 2012 - 12:47 PM
Here's my fix for market downloads. OK - it isn't my fix. But I did two hours of research to find it!
I sideloaded ROM Toolbox from my non-safe system, then used the following instructions from our XDA brethren:
allow root
go to "scripter"
save
After creating that script, I just ran it, and my queued downloads finished downloading.
Source:
Edit: Man.... getting all this working really makes me wish I could develop ROMs! I have so many ideas (pull the Camera drivers off the leaked ICS for the GSM RAZR, etc) but can't make them work because I don't know how! :( I guess I'll keep seeping off the system! hehe
#25 superstargoddess
superstargoddess
  • 139 posts
Posted 26 January 2012 - 01:00 PM
This is gorgeous and smooth. I like using Nova Launcher from XDA with it.
- Motorola Droid RAZR [IC3Razr- always most recent]
#26 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 701 posts
As far as getting apps back, I just put my ROM Toolbox Pro .apk on my SD card, made sure the backup I made with it was there as well, then installed and ran the App Manager and viola!
One thing worth noting, (if you have to) mess with your network settings to get data to work you have to do it every time you toggle the system in SafeStrap.
Thanks everyone involved! I've had the ROM installed maybe an hour and no FCs, no reboots, settling in extremely fast and effectively!
:-D :-D
#27 The Admiral
The Admiral
  • 21 posts
  • LocationSL,UT
Posted 26 January 2012 - 01:26 PM
Can't get native screenshots to work...
Edit: Can't press two buttons at the same time. The Admiral is still worthy of his n00b status. Working great!
#28 kindrudekid
kindrudekid
  • 42 posts
  • Twitter:kindrudekid
  • Google+:gplus.to/kindrudekid
  • LocationUS
Posted 26 January 2012 - 01:42 PM
Any1 facing issues with Wifi?
I was able to connect today morning and i returned home and it wont connect to my network saying avoided poor internet connection crap even when its gettin full signal or an just 5 feet away from my router.......
#29 Tmc363
Tmc363
  • 226 posts
  • Twitter:@tmc363
  • LocationHouston, Tx
Posted 26 January 2012 - 01:46 PM
No issues here
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here: http://www.droidrzr....-custom-titles/
#30 Tmc363
Tmc363
  • 226 posts
  • Twitter:@tmc363
Posted 26 January 2012 - 01:49 PM
You have to toggle it every time you reboot, turn it off, or safe strap but its well worth it. No blur and ics how does life get any better
