need help fastboot failure
Posted 16 February 2013 - 09:45 PM
i erasred cid. i try flash rom stock 4.04 but it display :
AP Fastboot Flash Mode (S) (Flash Failure)
OA.74
eMMC Info: 16G
Battery OK
OK to Program
Transfer mode:
USB Connect
invalid CG OTV (CG: system): invalid SP data
invalid CG HAB (CG: system, status: 0X004E)
anyone can help me . plz
Posted 16 February 2013 - 10:58 PM
Posted 17 February 2013 - 03:24 AM
Posted 17 February 2013 - 05:30 AM
Posted 17 February 2013 - 07:15 AM
Posted 17 February 2013 - 07:41 AM
1. He is Vietnamese so there is some basic difficulty in the translation, regardless of using Google or another translator
2. he has an xt912 that is in GSM world
3. His first issue was he flashed an xt910 file which borked his phone
4. He removed the CID as thats a step in the GSM world, without CID, afaik he will need to boot via BP Tools (which he says isnt working)
5. His Latest issue as of last evening was he couldnt get the phone to charge
I am more or less out of ideas but have learned a fair amount about GSM between pncanh and qss247.....not sure it helps though.
Posted 17 February 2013 - 07:42 AM
It looks like matts utility put u to stock so what happened when u tried to power the phone back on?
Matts utility failed in the screenshot....the preinstall img doesnt load
- pncanh likes this
Posted 17 February 2013 - 07:51 AM
how can i due with ?Matts utility failed in the screenshot....the preinstall img doesnt load
Posted 17 February 2013 - 08:18 AM
Posted 17 February 2013 - 08:30 AM
Posted 17 February 2013 - 09:39 AM
Posted 17 February 2013 - 09:42 AM
Posted 17 February 2013 - 10:17 AM
Posted 17 February 2013 - 01:38 PM
Posted 17 February 2013 - 04:55 PM
yes.Did you back up your CID?
so, dont have any solution ?
Posted 17 February 2013 - 05:01 PM
yes.
I'm looking to see if you can restore CID with boot menu manager. Maybe Matt can chime back in and see if its possible.
Posted 17 February 2013 - 05:03 PM
Posted 17 February 2013 - 05:08 PM
i cant go to rom, so i cant install BMM
Posted 17 February 2013 - 05:10 PM
you mean my phone diedSorry man
Posted 17 February 2013 - 05:21 PM
