Instructions for pulling an OTA update.zip:
- Do NOT install the update! Do these first!
- Be rooted. We got plenty of methods thanks to djrbliss.
- Download the Root Explorer app, or the ES File Manager app. (Instructions are for Root Explorer.)
- Open Root Explorer and go to the ~/cache/ directory, which resides on the root directory of the phone '~/'
- Hit the 'Mount R/W' in the corner, if successful will then say 'Mount R/O'
- Copy the update file .zip from the ~/cache/ to your sdcard, external to be safe.
- Copy over the update file .zip from the sdcard(s) you chose to your computer and upload it. is a good way to distribute large files for free.
- You will want to use Voodoo's OTA Rootkeeper before updating. --- Instructions for this are: Backup Root, Temp Unroot, Restore Root, Temp Unroot, Restore Root. ---
- Send me or post a link here to the update and exactly what System Version you were on, and where the update takes you to.
- The community will thank you for your help!
A note for the naming of update.zips:
They will always be named after the version that you are currently on, not the one you are going to. For example, when moving from Version 123-A to Version 124-B the zip would be named:
Blur_Version.123.A.XT912.Verizon.en.US and would NOT be named after where you are going to.
