Anyone running Liquid Smooth?
Posted 25 February 2013 - 10:22 PM
- charvaka likes this
Posted 26 February 2013 - 04:08 AM
Posted 26 February 2013 - 08:07 AM
Gotta get that rom crack lol
Posted 26 February 2013 - 09:39 AM
Posted 26 February 2013 - 10:03 AM
Ok thanks, the file size seems pretty small though, are there google apps that have to be flashed with it too do you know?You can find it on goo.im look for liquidsmooth under developers and then look for nickname spyder and you will find it there.
Posted 26 February 2013 - 10:08 AM
Gapps dated 2012-12-12 worked for me. The ROM file is just 100 MB or so, but it works fine. Gapps is almost as large as the ROM itself.Ok thanks, the file size seems pretty small though, are there google apps that have to be flashed with it too do you know?
Posted 26 February 2013 - 10:15 AM
Alright, thanks I'll give it a tryGapps dated 2012-12-12 worked for me. The ROM file is just 100 MB or so, but it works fine. Gapps is almost as large as the ROM itself.
- ninrulz likes this
Posted 01 March 2013 - 01:50 AM
Posted 01 March 2013 - 01:55 AM
Did you put it in slot1? A lot of these aosp base ROMs like slot 1 only.I can't get this to work anyone have any luck?
Posted 01 March 2013 - 02:01 AM
Posted 01 March 2013 - 06:50 PM
Posted 04 March 2013 - 09:24 AM
The camera works with the ICS kernel version. I had it on slot 2 and it worked as well. The JB kernel one only worked on slot 1.Hopefully source is released soon once JB is official as I understand should be able to fix camera at that point.
Posted 04 March 2013 - 02:51 PM
Posted 05 March 2013 - 11:38 AM
Posted 05 March 2013 - 12:02 PM
Yeah, it's solid! Super smooth and fast with a good amount of customization as well!
Any chance of posting the website for this ROM? I can't find it. Thanks
Posted 05 March 2013 - 12:18 PM
I never really found a website for it but the links for the rom are here: and here are the gapps:Any chance of posting the website for this ROM? I can't find it. Thanks
Posted 05 March 2013 - 12:26 PM
- downtheory likes this
Posted 05 March 2013 - 12:43 PM
Edit: I installed RC2 on top of RC1 without wiping data. I wiped cache and dalvik before flashing RC2. After flashing RC2, I also flashed the latest gapps (dated Mar 1). It is working great. The only difference I have noticed so far is a new Piecontrols tab in the ROM settings. I haven't figured out how to use it yet.
Edit 2: Pie controls work in this version. There are also a few more customization options than in RC1.
Edit 3: I lost the Update Center feature in system settings that used to check against goo.im for ROM updates. I installed the GooManager app from Play Store, and that seems to work.
Posted 05 March 2013 - 05:48 PM
Posted 05 March 2013 - 06:24 PM
This is a great rom, I haven't used Liquid since my D1 days.
Thanks for any help.
