Best Answer Memnoch73 , 22 March 2013 - 08:21 AM
Yeah use THIS it will get you going. Don't flash roms to your stock side. Go to the full post
Posted 22 March 2013 - 08:17 AM
Posted 22 March 2013 - 08:21 AM Best Answer
Posted 22 March 2013 - 09:09 AM
Posted 22 March 2013 - 09:13 AM
Ok thanks so much my phone was at 90% battery when it happened so I should be good on that part and I figured I'd just take the plunge and try to see if it works. Will I have to reroot my phone when I do this?
Posted 22 March 2013 - 10:07 AM
thanks lol i thought my phone was a gonerYes. You can do that with the same Utility.
Posted 22 March 2013 - 10:50 AM
Posted 22 March 2013 - 11:13 AM
worked like a charm lol
Posted 16 April 2013 - 05:57 PM
I did the same thing as the OP and tried to follow the steps but I cannot get my phone to boot into FastBoot help please
Posted 16 April 2013 - 06:09 PM
Posted 16 April 2013 - 06:23 PM
Turn off your phone.
Press and hold the following buttons at the same time until the screen turns on
1) volume down
2) volume up
3) power
Press Volume down until you reach the AP fastboot in the list
Press Volume up to select
Did you try holding all three buttons down? Wait you don't have to go into FastBoot to use matts utility just run it
You do need to be in fastboot. Except for rooting that is done through ADB when booted
Posted 16 April 2013 - 06:39 PM
Posted 16 April 2013 - 08:24 PM
If you are stuck with power on, hold all three buttons (simulates battery pull) until you get a white line that flashes at the top of the screen (means power is off). After this flash, immediately release buttons and then press all three again. If done quickly, it will put you into the fastboot menu. If not done quickly enough, the phone will reboot and you'll need to try again. I'm not sure if this is the best method, but this is how I enter FB mode if stuck in boot loop or on the red M.
Posted 18 April 2013 - 06:47 PM
Posted 15 May 2013 - 10:53 PM
Posted 15 May 2013 - 11:07 PM
Posted 16 May 2013 - 11:42 AM
Posted 16 May 2013 - 11:52 AM
I have a xt907 with a locked boot loader. I was on 4.1.1 and used utility 1.10 to get back to stock so I can update to 4.1.2 but it failed and left my phone in ap fast boot. I tried using utility 1.20 after i tried 1.10 at least ten more times and failed but I didn't know I needed an unlocked boot loader.
You have got to get something to flash correctly. Try just flashing a logo.bin to get out of the failed flash issue.
Posted 16 May 2013 - 11:55 AM
Posted 16 May 2013 - 12:07 PM
are all your drivers up to date?
Posted 16 May 2013 - 12:13 PM
