Posted 25 March 2013 - 09:36 AM
Posted 22 July 2013 - 07:56 AM
I am having a similar problem. Currently on Eclipse 4.2.2. Would like to stay on it and disable the HDMI port hardware. Any thoughts on whether that is possible?
Posted 22 July 2013 - 08:54 AM
It sounds more to me like the device believes you have an HDMI cable in. I would turn your device off then clean out the HDMI port carefully with something like alcohol and a small brush or lint free paper folded tightly. Don't pour the alcohol in obviously and let it evaporate completely before turning on again.
- johnthehillbilly likes this
Posted 22 July 2013 - 09:54 AM
Sent from my XT926 using Tapatalk 4 Beta
Posted 22 July 2013 - 10:26 AM
Do you have an hdmi cable? Try putting it in and out and see if it clears it as well. You said it was soda, so I would bet you got some sticky stuff down in there that is bridging the tabs,.
Posted 22 July 2013 - 10:28 AM
Posted 22 July 2013 - 02:57 PM
... telekinectically tapping, tenaciously traversing the terrain...
- shane1 likes this
Posted 22 July 2013 - 03:22 PM
Or you could do like I did..... take the phone apart and remove the HDMI port alltogether and put a "blob" of silicone over the connections as not to short anything out .... voilĂ no more HDMI problems..... ever LOL
um yeah thats a hillbilly fix lmao
sig made by
Rinkle McBally
Posted 22 July 2013 - 03:40 PM
Also tagged with one or more of these keywords: hdmi, problem
