{FXZ}{system.img} XT926 4.1.2 (9.16.9) DST (Unlocked Bootloader Required)
Posted 11 April 2013 - 12:29 AM
Posted 11 April 2013 - 04:14 AM
When you say that this fxz will return the device to its original condition does mean it will lock the bootloader again and no root? Or to the way i have it right now with 4.1.2 rooted, unlocked bootloader and safe strapped?I made a full fxz of my dst rom from here:
You can flash the full fxz with rsdlite or the individual partitions with fastboot.
It includes the stock moto logo (no nag screen), latest twrp recovery (2.5.0.0), and the dst system. everything else is stock.
thanks to Aixelsyd for making the ext4 system.img
thanks to hashcode for making the twrp recovery
thanks to moto for getting dickslapped
dan rosenberg's donation page:
hashcode's donation page:
FAQ:
what is fxz? Fastboot Xml Zip - fxz is a full restore file to return your device to its original condition
what is rsdlite? rsdlite is a flash utility for motorola devices
what is fastboot? fastboot is a command line binary used to flash the individual partitions of a fxz
still have questions? please try to search for an answer before asking in this thread
Posted 11 April 2013 - 06:10 AM
Posted 11 April 2013 - 06:13 AM
- mhous33 likes this
Posted 11 April 2013 - 06:19 AM
Thanks, it's been awhile since most moto users have experienced true freedomGreat stuff here mhous33!!
- trikotret and bdazzg1 like this
Posted 11 April 2013 - 07:27 AM
Posted 11 April 2013 - 07:47 AM
Posted 11 April 2013 - 08:52 AM
Fxz is a compete restore file that flashes every possible partition.
Posted 11 April 2013 - 11:17 AM
<step operation="flash" partition="logo" filename="logo.bin" MD5="cd111cc7b675e62a7d85a50632fb88e8" />
Posted 11 April 2013 - 11:25 AM
Posted 11 April 2013 - 11:29 AM
Posted 11 April 2013 - 11:30 AM
Mine failed on flashing system.img...now i boot directly into fastboot. Any ideas how to fix this?
yeah, unlock your bootloader.
Posted 11 April 2013 - 11:32 AM
you can remove the line completely or replace the logo.bin with the one from the stock fxz and change its md5 value back to the original. the one i use is pulled from an xt885 fxz.
Ok cool, thanks man.
Posted 11 April 2013 - 11:37 AM
I have a developer edition thats unlocked
Posted 11 April 2013 - 11:50 AM
that is strange. at least one other person has flashed this without any problem. i don't have a razr hd, so unfortunately i can't help troubleshoot. i did test the one i made for the razr m using the same process and it worked flawlessly.
Posted 11 April 2013 - 11:56 AM
if you haven't yet, try flashing just system.img with fastboot:
Posted 11 April 2013 - 12:00 PM
btw, were you using rsdlite or fastboot?
Yeah i have tried flashing just the system.img in fastboot, i was using rsdlite before. The 4.1.2 orginal fastboot file gives me the same error, im charging the phone in factory mode and will try again later. Thanks for the help
Posted 11 April 2013 - 12:08 PM
this looks like the ideal place for a shameless plug for the tbh factory adapter...
Posted 11 April 2013 - 12:50 PM
