well i feel like an idiot, forgot to update RSD Lite to the latest version...Fastbooted successfully and time to enjoy XT926 4.1.2 DST
cool, glad you figured it out
although that doesn't explain why fastboot failed...
Posted 11 April 2013 - 12:52 PM
Posted 11 April 2013 - 01:17 PM
well i feel like an idiot, forgot to update RSD Lite to the latest version...Flashed successfully and time to enjoy XT926 4.1.2 DST
Posted 11 April 2013 - 01:32 PM
Mhous33 Perhaps you could edit the OP to make mention of the current RSD version. For future reference.
Posted 12 April 2013 - 12:12 AM
Posted 12 April 2013 - 04:07 AM
Gunnerkid's fastboot most likely failed because he wasn't using the snapdragon fastboot. The one from the Android SDK won't work.
Posted 12 April 2013 - 04:11 AM
Posted 12 April 2013 - 04:57 AM
It worked. I bought onethis looks like the ideal place for a shameless plug for the tbh factory adapter...
Posted 12 April 2013 - 10:49 AM
Posted 12 April 2013 - 11:26 AM
This worked well for me and runs very smooth. Thanks OP!
Only thing I noticed is the Smartactions app wont update from the play store. Says the "Package file was not signed correctly". Just wanted to give you a heads up. Thanks again!
Posted 12 April 2013 - 07:27 PM
thanks for pointing that out! that is the one moto app that is updatable from the market, and it is originally odexed, which means it got deodexed, signed, and zipaligned, and then reodexed for the odexed build. so when you go to update it, its signature is different than what is expected. google apps are the same, but most of them are deodexed to begin with. you can either live with the outdated version, or delete it, reboot, and install from the market.
Posted 12 April 2013 - 10:39 PM
That worked perfectly. Thanks again mhous33, this Rom is sweet!
Posted 12 April 2013 - 10:56 PM
Posted 12 April 2013 - 11:06 PM
Might be a dumb question but I didn't see it, will this delete user data? As in music, images, stuff like that? Not as in the apps and crap, thats all replaceable.
Posted 12 April 2013 - 11:14 PM
Posted 12 April 2013 - 11:33 PM
Posted 12 April 2013 - 11:50 PM
i knew i was gonna mess up lol...I don't know what i could have done wrong i'm using RSD Lite 6.1.4, Moto Drivers 5.0.9 and the .xml on the OP but i get a FAIL to flash, at what point do i click on the snapdragon fastboot or Binaries?? and how do i use that file?
Posted 13 April 2013 - 12:01 AM
Posted 13 April 2013 - 12:07 AM
I'm using RSD Lite and i'm getting a Failed to switch to fastmode
Posted 13 April 2013 - 12:13 AM
Yes my boot loader is unlocked i just replace stock recovery with TWRPAt what point does the flash fail? If you're not sure, try again and take note.
Just to be sure, your bootloader is unlocked, right?
Posted 13 April 2013 - 12:37 AM
