[Solved] Help, Razr Maxx HD XT926 bricked after root
Razr Maxx HD bricked XT926
12 replies to this topic
#1 philly81
philly81
  • 5 posts
  • LocationPennsylvania
Posted 12 April 2013 - 02:59 AM
Please help. I recently rooted my Droid Razr Maxx HD phone successfully using the new exploit by Dan. Everything worked fine until I went to install the app "VM Heap" to get better performance. I attempted to reboot the phone after installation like the app suggested, & now my phone stays stuck on the " Droid eye" opening sequence. I'm assuming I will need to wipe the phone & do a factory reset through AP Fastboot, but I cannot find the right utility to acheive this for XT926 Jelly Bean 4.1.2. Someone please advise. Your help is much appreciated.
#2 Narffran
Narffran
  • 147 posts
  • Twitter:Fran_Granfield
  • LocationNorth of Boston MA
Posted 12 April 2013 - 07:37 AM
From a powered off state Can you get to the boot menu? If so this is how to do a reset:
  • Power the device off.
    Posted Image Press the Power button then select Power off.
    Posted Image If the device doesn't respond to input, press and hold the Volume Up/Down then press and hold Power button. When the device screen goes blank release the Power button while continuing to hold Volume Up/Down, proceed with step 3.
  • Press and hold the Volume Up/Down then press the Power button.
  • When presented with the Boot Mode Selection Menu release all buttons.
  • Press Volume Down to select Recovery then press Volume Up.
  • From the Droid triage screen, simultaneously press Volume Up/Down.
  • Select wipe data /Factory Reset then press the Power button.
    Posted Image Use Volume keys to navigate options.
  • Select Yes -- delete all user data then press the Power button.
    Posted Image Data wipe may take several moments.
  • Select reboot system now then press the Power button.
#3 cmh714
Posted 12 April 2013 - 07:49 AM
Boot into Recovery and try the wipe, that often takes care of the bootloop your in.
#4 philly81
philly81
  • 5 posts
Posted 12 April 2013 - 08:28 AM
I have completed the wipe in recovery mode, & rebooted from there as well, but it is still bootlooping. Any other suggestions?
#5 cmh714
Posted 12 April 2013 - 09:48 AM
If wiping didnt fix you, then I think it needs a flash
#6 philly81
philly81
  • 5 posts
Posted 12 April 2013 - 10:04 AM
Where can I find the flash?
#7 cmh714
Posted 12 April 2013 - 12:50 PM
I dont have a 926 so I would look in the 926 area in the forum. There is probably a utility in there.
The SBF files can be found here though:
#8 philly81
philly81
  • 5 posts
Posted 12 April 2013 - 02:03 PM
Ok, I'll give it a whirl. Thanks for your help.
#9 philly81
philly81
  • 5 posts
Posted 12 April 2013 - 03:30 PM
The flash worked like a charm. Thanks again!
#10 cmh714
Posted 14 April 2013 - 07:19 AM
Fantastic.
#11 Skyler
Skyler
    Droidberg
  • 16 posts
Posted 26 August 2013 - 02:52 PM
I have a similar problem. I have a Razr HD (XT926) that got stuck in a bootloop after updating a rom I had been on for a long time. I tried sbf-ing using RSD Lite with several SBF files (4.1.2, 4.1.1, etc.) as well as using the DROID RAZR HD Utility 1.21. I'm able to get into TWRP recovery but everything from my SD card is gone, so I can't restore/flash any rom for it to run so when I power it on it just sticks on the bootanimation....any help, or am I looking at a very expensive paper weight at this point?
#12 toty556
toty556
  • Locationyemen
  • Current Device(s):motorola droid razr hd
Posted 22 March 2015 - 09:24 AM
link error
cmh704
#13 livinginkaos
  • 15,104 posts
Posted 22 March 2015 - 09:47 AM
The SBF site has been taken down. You can go here -
sent from my N6
