So I was able to finally get my Droid Razr Maxx HD rooted, but I am at a loss as to how to get Wifi tethering working with Jellybean. I can currently do the Bluetooth tethering but this doesn't work with a lot of my devices as they aren't as fancy as the phone and do not have Bluetooth. I feel like this is something simple and that I'm just missing some terminology or common expression in the how to guides. Any help?
Wifi tether on Droid Razr Maxx HD
memyselfi111
, Apr 13 2013 03:07 PM
7 replies to this topic
Posted 13 April 2013 - 03:07 PM
Posted 13 April 2013 - 06:13 PM
SQ Lite hack or wifi tether version 3.2-beta2 ***BETA***
both work on my rooted/unlocked MAXX HD
Posted 13 April 2013 - 06:51 PM
Thanks for responding -- I tried the wifi tether version 3.2 but it's failing to load the wifi driver. What specific settings are you using? Or do you remember?
Posted 13 April 2013 - 06:59 PM
Okay, just got it working with the experimental 3.3 2 with the following settings:
1)Change Device Profile to Generic ICS/JB(wlan0)
2)Make sure Setup Method is set to Auto
3)Wifi Driver reload, MSS clamping, and Routing Fix is Checked.
Posted 13 April 2013 - 07:18 PM
Thanks for all the help! I don't want to be a jerk and start another separate topic on the board but is there a surefire way to block any new OTA updates? I don't want to lose this now that the WIFI is actually working.
Posted 06 August 2013 - 03:42 PM
Disable Moto services and you will never see no update nagging!
Posted 06 August 2013 - 04:29 PM
or freeze the updater.apk
sig made by
Rinkle McBally
Posted 09 September 2013 - 11:15 AM
Moving to: VZW Droid Razr/Razr Maxx HD General [XT926] - {Q&A, Discussion}
Reason: Non-emergency
