OK since a lot of people decided that the file being pulled until all the bugs were address didn't apply to them, and went ahead and found the leak elsewhere, ignoring the constant warnings that it is extremely dangerous to do so, we are posting this thread to help anyone who needs to get back to 6.12.173.
Here are the fastboot files needed to return to .744:
And here is a good thread with step-by-step instructions on how to use the fastboot files above and RSD to return to stock:
A couple things to remember:
- Make sure you have at least 70% battery left!
- DO NOT use Matt's utility, it will not work.
And last but not least:
- MAKE SURE YOU HAVE AT LEAST 70% BATTERY LEFT!!!!
And here's a thread on how to charge your battery if you tried to use RSD on a low battery anyways:
Rest of post in progress...
Edited by VantenKiest, 03 April 2012 - 04:38 PM.
no longer available :D
