Ics Ring And Notification Sound
8 replies to this topic
#1 fbm111
fbm111
  • 56 posts
  • Twitter:fbm111
Posted 01 April 2012 - 05:34 PM
Anyone know of a way or if it its possible to link the ring and notification volumes? I use ringdimmer and it won't auto set notification volume now that i can't link it to ring volume.
#2 chuckyteets
chuckyteets
  • 33 posts
Posted 09 April 2012 - 09:43 AM
bump! just did the verizon leak sideload thing to get ICS and keep root. notification volumes are separate from ring volume, and there is no option to link them back together. I've tried a few apps but none of them can link them unless the app itself is open any time you want to change volumes
#3 Averix
Averix
  • 19 posts
  • Twitter:_Averix
Posted 29 May 2012 - 02:17 PM
Has anyone found a solution for this? Kind of a pain that you can't link them together anymore.
#4 Guest_BDH_*
Guest_BDH_*
Posted 29 May 2012 - 02:22 PM
System Settings > Sounds > Volumes
Its there for me on KOA ROM but that's CM9 based. Could have swore it was on the .75 leak as well.
#5 chuckyteets
chuckyteets
  • 33 posts
Posted 01 June 2012 - 10:48 AM
yeah i'm on KOA now too on .206 and it is there, but it was not there on stock .206.. so goofy. there's got to be a simple mod to fix it on stock setups if CM9 can do it
#6 qoncept
qoncept
  • 29 posts
Posted 20 June 2012 - 01:15 PM
I'm on the .211 leak now and I'm not seeing a way to link them. I have a rule in Smart Actions to turn my ringer volume way down during work, but there's also no action to change the notification volume. And the volume buttons only affect ringtone, not notifications. Stupid.
#7 my2cents
my2cents
  • 32 posts
Posted 27 June 2012 - 09:47 AM
I've also been trying to figure out a solution. No simple ones exist and I cant seem to find a complex one either. I might have to try a CM9 based rom. Anyone find a way to link them yet?
#8 qoncept
qoncept
  • 29 posts
Posted 02 July 2012 - 07:58 AM
Did anyone ever get anywhere with this? I don't want to install a rom.
#9 maxximized 234
maxximized 234
  • 5 posts
Posted 13 July 2012 - 01:50 PM
anyone?
