[Bootstrap Recovery] Ics Leak Specific
#21
Posted 02 April 2012 - 09:23 AM
#22
Posted 02 April 2012 - 09:33 AM
Guys you gotta read all 3 posts. I installed the touch recovery but it wouldn't work at all. I then installed just the regular bootstrap recovery that you have to use the hard buttons for. I believe I posted the link in post 2 or 3. The Beats Audio zip that I flashed is one I have on my phone from XDA. I'll post it later today.Post 2 has the link for the recovery that works.
Sent from my Rooted Stock ICS Droid RAZR using tapatalk.
I saw it on xda too but it's just hard looking thru all the files to find the right/latest zip for the razr...if you wouldn't mind posting it that would be awesome. thanks!
(p.s. your link to the working recovery in the op isn't working, just a heads up!)
#23
Posted 02 April 2012 - 09:39 AM
I couldn't believe it when it booted into recovery. Even more shocked when I was actually able to flash a zip file with it successfully. This is awesome lol!
does the Beats zip really make a big enough of a difference to actually get it?
#24 Guest_BDH_*
Posted 02 April 2012 - 10:35 AM
Definitely makes a difference. Music playing from my phone through my car has never sounded better. Getting ready to post the zip in a couple minutes. Just gotta add a line in the updater-script to mount /system for you.
Beats Audio (flashable zip) link:
No wiping of anything is needed. Just boot into recovery, flash the zip, reboot and enjoy Beats Audio on your RAZR.
#25
Posted 02 April 2012 - 10:48 AM
thanks for the upload!! i looked at the size of your zip, are you aware of the newer versions available at the xda thread? have u had any luck with the 3/14 or 3/17 versions? or is this the most compatible for the razr? thanks again!
#26
Posted 02 April 2012 - 10:59 AM
#27 Guest_BDH_*
Posted 02 April 2012 - 11:23 AM
I thought beats only worked with gingerbread?
Nope. Works with ICS too.
#28
Posted 02 April 2012 - 12:56 PM
#29
Posted 02 April 2012 - 01:19 PM
so i flashed the beats.zip. is there supposed to be an icon or something? im totally lost :/
im at the same place as you...theres also so many different versions besides the one he posted (which looks outdated?) so i'm just trying to get a little more info on the beats audio working with this new ics leak. if you figure anything out lemme know!
#30
Posted 02 April 2012 - 01:34 PM
definitely validating picking up the maxx and getting rid of the Nexus and Rezound... ICS, crazy battery life... beats audio... can't think of anything else i really could want sans the 720p screen
#31
Posted 02 April 2012 - 02:16 PM
#32
Posted 02 April 2012 - 06:15 PM
- evan30 likes this
#33 Guest_BDH_*
Posted 03 April 2012 - 10:53 AM
Regarding the issue with Beats Audio, there is no icon or app. Just flash the file and start listening to music. I don't really know about "updated" versions and don't see why they would be updated. They're pretty much just equalizer settings. If you find an updated zip, you can send me the link and I'll add it to the OP but I'm not going to go searching for it because this zip works perfectly fine. If for some reason, you're not noticing a difference, try mounting /system in recovery before flashing and see if that helps. If it does, let me know and I'll add those instructions to the OP as well.
#34
Posted 03 April 2012 - 06:32 PM
EDIT: I even tried to do a factory wipe in the stock recovery (since i cant get into Bootstrap) and its still all messed up. :/ Now i have to wait till i get off work to go back to .173 then hopefully get root again on ICS
#35
Posted 03 April 2012 - 06:39 PM
Once you go back to. 173 you may not be able to get back to ICS, files have been removed, good luck.I dont know if anyone decided to try this, but i restored the backup that i made using Bootstrap and my screen is all kinda of messed up now :/ So i recommend NOT restoring a backup. unless someone else has and had it work?
#36
Posted 03 April 2012 - 08:50 PM
When was the last time you tried this? From what i read since the file was removed (recently) from server that trick might not work. Let us know if it works for you. Sent from my DROID RAZR using Tapatalk
i did it before it was removed from the server. i will try to just flash them through recovery whenever i get home from work. Maybe ill finally get my Soak Test and i wont have to worry about all this. lol
EDIT: Regardless, the point is to NOT restore a backup with Bootstrap while on ICS. unless i just got screwed and it only messed up for me. lol
#37 Guest_BDH_*
Posted 05 April 2012 - 09:44 PM
#38
Posted 06 April 2012 - 06:48 PM
Woo17 did you clear cache b4 backup, and wipe data before restore?
sliced by my Razr on Tapatalk
#39 Guest_BDH_*
Posted 06 April 2012 - 07:03 PM
Ok Hicks says nano restored successfuly, Woo17 says major fail, can we get any more info.. confirmations, or failures?
As I said, I haven't tried a nand restore. Now that we have a way to sideload the ICS leak, I'll give it a shot and post my results in a little bit.
#40
Posted 06 April 2012 - 07:10 PM
Not trying to be smart but it looks like you did say it works?EDIT YET AGAIN!!!!
Just keeps getting better and better!!!!!! Successfully restored my nandroid backup, successfully flashed the Beats Audio, successfully mounted /system in recovery. Looks like the bootstrap recovery v5.0.2.5 works with everything!!!! If you kept root while updating then you should be good to install this recovery and use it. However......I AM NOT RESPONSIBLE FOR YOUR PHONE MELTING OR EXPLODING!!!!!!!!
Also tagged with one or more of these keywords: recovery, ics, leak, custom recovery, ics recovery
