Best Answer Memnoch73 , 18 April 2013 - 06:22 PM
Did you mount system before installing the rom??
Go to the full postBest Answer Memnoch73 , 18 April 2013 - 06:22 PM
Go to the full postPosted 18 April 2013 - 06:21 PM
I'm attempting to install the latest Nexesque rom from TWRP and I get the following:
E: Unknown File System: 'datamedia'
Updating partition details
Installing '/external_sd/Nexesque_RazrHD v3.0.zip
Checking for MD5 file...
Skipping MD5 check: no MD5 file found.
Flashing file 1 of 1
/external_sd/Nexesque_RazrHD v3.0.zip...
That is all. It has been sitting like this for nearly an hour now with no change whatsoever. What do I do? Is there some way I can abort?
This is my first custom ROM so I'm obviously new to this. I did do a backup with TWRP before I started, but I don't know how to get out of the current screen.
Posted 18 April 2013 - 06:22 PM Best Answer
Posted 18 April 2013 - 06:31 PM
No I didn't know that was required?
How can I abort the current flash sequence so I can at least go back to my backup, or retry with system mounted?
Posted 18 April 2013 - 06:33 PM
Yes it is required.
Umm.. You can try holding all 3 buttons for 10 sec and see if you can get it to power off then go back into bootloader/recovery and start again
Posted 18 April 2013 - 06:43 PM
Posted 18 April 2013 - 06:44 PM
Thanks! I actually did try that but not for the full 10 seconds apparently.
Rom installed succesfully!
Posted 18 April 2013 - 06:45 PM
Read the entire op before attempting to install ANYTHING on your phone..... Just a tip
I did but just don't recall anything about having to have system mounted. What does this do anyways?
Posted 18 April 2013 - 07:51 PM
Posted 19 April 2013 - 07:40 AM
Ss done it for you before you flashed but twrp doesn't for some reason all it does is mount your system partition so it can be wrote on
Well lesson learned. Make sure you have system mounted in TWRP before flashing ROMs. Thanks for your help everyone. Phone is up and running Nexesque 3.0 and it is SMOOOOOTH as silk. I love it.
Posted 22 April 2013 - 11:43 AM
Note that the bolded only applies if you are flashing a ROM that was originally made for installation on Safestrap.
