XT 907 HELP please...
69 replies to this topic
#1 biozombie
biozombie
  • 45 posts
  • Locationmichigan
  • Current Device(s):xt907
Posted 20 April 2013 - 02:19 PM
I have a xt 907 i think i f%$ked it up... i unlocked this phone and have been trying new roms with safe strap 3.12 i finally found one i liked so i was goin to install it as my main rom so i wiped the factory rom and for some reason Mrage did not want to instal on that slot i accidentally rebooted now safestarp says its disabled when i hit the recovery button it does nothing screen goes black and i have to do a volume down and power to reset it I CANT ENTER SAFE STRAP  AHHHHHHHHH.... if anyone has any good ideas please throw them at me im going to continue to play with it but i have no roms installed now and cannot enter safe strap...
#2 lowvolt
lowvolt
  • 478 posts
Posted 20 April 2013 - 02:46 PM
Download RSD lite and the Razr m fastboot files. Pput your phone in bootloader mode and fastboot back to stock.
#3 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 20 April 2013 - 02:53 PM
Use matts utility to go back to stock
  • neckchop likes this
#4 biozombie
biozombie
  • 45 posts
  • Locationmichigan
Posted 20 April 2013 - 03:01 PM
i download RSD lite and the latest fasboot files... what did i do wrong im new to safestrap and the razr's always had Evos before i went to verizon....
#5 lowvolt
lowvolt
  • 478 posts
Posted 20 April 2013 - 03:10 PM
it sounds like you wiped the system and rebooted. No Operating system no phone.
#6 lowvolt
lowvolt
  • 478 posts
Posted 20 April 2013 - 03:11 PM
do you have a link. I have RSD lite and fastboot files but It fails. I would like to go back to stock then unlock my bootloader and take the OTA.
#7 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 20 April 2013 - 03:13 PM
Are you able to get into ap fast boot? You said you were running safestrap, had you unlocked your boot loader yet? Dies your battery have a decent charge on it?
#8 neckchop
neckchop
    pluh!
  • 477 posts
Posted 20 April 2013 - 03:17 PM
Try the utility here.
#9 biozombie
biozombie
  • 45 posts
  • Locationmichigan
Posted 20 April 2013 - 03:18 PM
yea but why didnt safestrap work after it rebooted...
#10 neckchop
neckchop
    pluh!
  • 477 posts
Posted 20 April 2013 - 03:19 PM
Also, give this thread a read, its a similar issue and may help your situation, even if only to get you into fast boot.
#11 biozombie
biozombie
  • 45 posts
  • Locationmichigan
yea im in fastboot im using RSD lite as we speek...
#12 biozombie
biozombie
  • 45 posts
  • Locationmichigan
Posted 20 April 2013 - 03:21 PM
but it seems like RSDlite Hung up on me stoped at status 8/19 flash modem "NON-HLOS.bin" 15 min hasnt changed should i retry it?
#13 neckchop
neckchop
    pluh!
  • 477 posts
Posted 20 April 2013 - 03:24 PM
The only way I've been able ton succesfully flash a ROM onto the stock slot using safe strap was to make a backup of that ROM in slot 1, then delete slot one and activate the stock slot. Then restore the backup of the ROM from the old slot into the stock slot. I think by doing this (someone, feel free to chime in here if i have this wrong )you retain the kernel. From what I understand, most of our ROMs were built for safe strap and didn't need the kernel included because they ran from the kernel in the stock slot.
Again, if I've got this wrong, please someone correct me. Haha.
Keep us posted if you get your phone running dude! I would consider unlocking your boot loader and using twrp. Save yourself some space!
#14 lowvolt
lowvolt
  • 478 posts
Posted 20 April 2013 - 03:25 PM
Can you use Matts Utility in Fastboot? Or is that how you have to use it? Like I said RSD is failing for me.
#15 neckchop
neckchop
    pluh!
  • 477 posts
Maybe, but I wouldn't try to do too many things at once. Your battery only has so much juice left in it. While I applaud the use of rsdlite Matt's 1.10 utility has been the easiest surefire way to get going again in my experience
#16 neckchop
neckchop
    pluh!
  • 477 posts
Posted 20 April 2013 - 03:27 PM
To use the restore option, yes, you HAVE to be in fast boot. It'll give the instructions when you select option one, before attempting to flash anything.
#17 biozombie
biozombie
  • 45 posts
  • Locationmichigan
Posted 20 April 2013 - 03:38 PM
im downloading matts utility rsd lite aint working ok so after i get this fixed should i stick with safestrap or is there any better bootloaders out there?
#18 biozombie
biozombie
  • 45 posts
  • Locationmichigan
Posted 20 April 2013 - 03:39 PM
safestrap kinda f%$ked me i didnt know it needed the stock kernel to boot itself...
#19 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 20 April 2013 - 03:41 PM
If your unlocked try twrp or cwm but ss is ten times easier if you don't know what your doing and a safety feature in ss don't allow you to directly flash on stock side but you can restore a backup on stock I recommend you make a backup of stock rom just in case something goes wrong
  • neckchop and shane1 like this
#20 neckchop
neckchop
    pluh!
  • 477 posts
Posted 20 April 2013 - 03:45 PM
Safe strap foes work, but you have to see it in a roundabout way is all. If you unlock your boot loader and want to flash a recovery, twrp 2.3.2.3 seems to be doing the trick. It takes a bit of getting used to, but keep reading around and you'll figure it out :-) or send me a pm. There's plenty of guys that have been doing trial and error on the M, and they'll get you hooked up pretty well. (Shane, Brandon, Rik, aixelsyd, to name a few)The RAZR M DST thread has some good info also. My best advice is to read, read, read some more, and don't be afraid to ask questions. Learn as much as you can. This a great friendly community, and its great to have you here. Now, let's get your phone fixed. Lol
  • shane1 and brandon71 like this
