XT 907 HELP please...
69 replies to this topic
#61 SLErnesto
SLErnesto
  • 18 posts
Posted 05 May 2013 - 09:32 PM
Those didn't work and I tried 5.9. Nothing
#62 mhous33
mhous33
  • 480 posts
Posted 06 May 2013 - 03:43 AM
Can someone help me? i have a gsm unlocked xt907 thats stuck in ap fastboot mode, it says flash failure. ive tried to go back to stock 4.0.4,4.1.1, and 4.1.2 with RSDlite and Mattlgroff's utility but no luck with either. ive uninstalled and reinstalled everything again and again but nothing works. RSDlite fails to flash the modem NONHLOS.bin and MAtts utility gets stuck at sending rpm....
That doesn't make sense. Might try flashing everything except the radio though and see if it succeeds.
Open the xml file of the fxz and comment out the radio flashing instruction:
<blah modem NON-HLOS.bin blah>
<!--blah modem NON-HLOS.bin blah-->
Then flash with rsdlite.
#63 SLErnesto
SLErnesto
  • 18 posts
Posted 06 May 2013 - 10:44 AM
Tried and it failed at 10/17 flash logo "logo.bin". I'm using rsdlite 6.1.4
#64 SLErnesto
SLErnesto
  • 18 posts
Posted 06 May 2013 - 10:53 AM
Tried again skipping logo.bin too and it failed at flashing boot boot.img. on the razr m it says downgraded security version
Update gpt_main version failed
Preflash validation failed for GPT
#65 mhous33
mhous33
  • 480 posts
Posted 06 May 2013 - 11:04 AM
If you've already flashed 4.1.2 and don't have an unlocked boot loader, you are stuck on 4.1.2.
Doesn't make sense that it's failing on logo though as that is not a secure partition.
I'm guessing you have a driver issue or an issue with your usb connection.
#66 SLErnesto
SLErnesto
  • 18 posts
Posted 06 May 2013 - 11:13 AM
Yeah I think so. Rsdlite shows fastboot smq in model instead of xt907. Any specific drivers that work?
#67 mhous33
mhous33
  • 480 posts
Posted 06 May 2013 - 12:42 PM
smq = scorpion mini qualcomm
So it is seeing your device.
Are you using usb 3.0 by chance? That is a no no.
  • shane1 likes this
#68 SLErnesto
SLErnesto
  • 18 posts
Posted 06 May 2013 - 12:57 PM
No. 2.0
#69 SLErnesto
SLErnesto
  • 18 posts
Posted 08 May 2013 - 08:06 AM
I tried Matt's utility 1.20 and it said it succeded but the phone never restarted and stayed in ap fastboot mode.
#70 anth0nyd0nahue
anth0nyd0nahue
Posted 31 July 2014 - 11:06 PM
i've been trying this all freaking day. finally got to see my wallpaper again. thank you so much. <3
