Ics Bugs, Tricks And Oddities
Posted 05 April 2012 - 05:34 AM
What I've seen so far:
1. Temple run has a possible bug sensing swipes. Needs confirmation to be a bug.
2. Browser widget seems to open the bookmark db preventing using sqlite to delete locked crappy bookmarks. Trash widget temporarily and make sure browser closed seems to allow editing.
3. Found a new one. Google email widget seems to lose account link often and has to be trashed/redone to work. Real annoying.
Posted 05 April 2012 - 05:48 AM
Posted 05 April 2012 - 05:57 AM
Posted 05 April 2012 - 06:07 AM
Temple Run & Running Fred doesn't recognize when you lift your finger (Temple Run thinks you're constantly tapping the screen wherever you lift it)
Can Knockdown has a similar bug
Face unlock is super super laggy and you can put in your password through it sometimes
First boot is slow as all hell
When you have no data, there is still an invisible icon in its place
Sometimes swiping through app drawers will freeze in the middle of the animation
The favorite contacts widget can be dragged with the finger without long-pressing but doesn't do the cool cascading thing from GB
If you press a hard button during the CRT animation the screen will turn right back on after it ends
The green tint on low brightness is mostly gone
The manual brightness can be set WAY lower, but that setting isn't part of auto-brightness yet
Posted 05 April 2012 - 06:11 AM
Posted 05 April 2012 - 06:38 AM
I can confirm the Temple Run bug. Another thing other people (myself included) are experiencing, I get a text message that reads something like VZWXE1 , several times a day. Next time I get one I'll post it exactly as it shows.
This isn't a bug, I'll post the fix when I get home.
Posted 05 April 2012 - 06:46 AM
- Hardtime3015 likes this
Posted 05 April 2012 - 06:51 AM
Cut The Rope, Kona's Crate and numerous other games FC before you can play anything.
Bluetooth hangs between on and off leaving you unable to toggle and requiring a reboot to fix.
Posted 05 April 2012 - 06:59 AM
Sound works for me with bluetooth on. Haven't paired yet though
What's hotplug? Is that why i don't have an option to charge only when usb connected?
Posted 05 April 2012 - 07:01 AM
New governor is 'interactive'
been getting ridiculous touchscreen behavior at times
**may be related to the otterbox touching, I'll try to duplicate it.
Anyone get ics camera +? I'd like to make the funny faces work.
anyone test bootstrap?
last,more games are compatible,AFAIK
Posted 05 April 2012 - 07:26 AM
No, the new governor is "hotplug", which was present before too. mot_hotplug is gone though, you're right.Moto_hotplug governor is MIA.
Try to use it practically, though. It definitely lags a lot as the camera is starting up, it adds a whole 5ish seconds to your unlock routine at the very least, especially if you're trying to hit the little lock button so you can just put in your passcode because it's too dark. Doesn't do that on the GNEX.I'm using face lock now and having no troubles so far. Doesn't seem to lag but I'm not running anything in the background.
Posted 05 April 2012 - 07:28 AM
Does your guys launcher (Apex or Stock) app drawer stop halfway between two pages sometimes? Or is it just mine?
Confirmation would be awesome.
Posted 05 April 2012 - 07:35 AM
5ish seconds? I can unlock easily in less than 2 seconds, from wake button to homescreen.
Posted 05 April 2012 - 07:36 AM
Swiping must be a little goofy right now in general.
Yea that's happened to me
Posted 05 April 2012 - 07:39 AM
No trouble with app drawer so far
Posted 05 April 2012 - 07:42 AM
i think i rad somewhere that that option was removedAnyone find option to charge only on usb connection?
Posted 05 April 2012 - 08:03 AM
I used bootstrap to install Beats Hack. It works, not that Beats does, but the install does.
I lost several contacts. I didn't want to call the wife anyway. She will just want chores out of me, if I do get in touch with her.
- composi likes this
Posted 05 April 2012 - 08:05 AM
Posted 05 April 2012 - 08:14 AM
I'm positive there is a governor called interactive now, according to rom toolbox.
Also built in screenshot is Vol-down and power.
Can't get overclock modules to load atm
Random market download error when downloading apps.
- flukeshot likes this
Posted 05 April 2012 - 08:18 AM
Every device has interactive, conservative, & ondemand. on GB we had interactive, conservative, ondemand, hotplug, and mot_hotplug, mot_hotplug being the default. On ICS we have interactive, conservative, ondemand, and hotplug. no mot_hotplug, and hotplug is the default.I'm positive there is a governor called interactive now, according to rom toolbox.
