Help with phone!
43 replies to this topic
#1 Griff
Griff
  • 17 posts
  • Current Device(s):Razr M XT907
Posted 21 April 2013 - 10:38 AM
Hi everyone,
 First post and it is with problems go figure. I have been messing with Android phones since my first Droid X . Now I have the Razr M and love it until today. I was on VZW_XT907_4.1.1-9.8.1Q-27-2-4_1FF and rooted, bloat ware removed.
 All was doing fine till today with a moment of brain failure I noticed going into about phone an update . So without even thinking twice I updated. Then it dawned on me crap! I should have installed all bloat ware back and unrooted device. So now when I power off and power on it goes into what looks like fastboot and says flash failed all white letters. Tried to use RSD to install default SBF again nothing. says failed while trying to flash, Can you guys help me on this issue.?
I just came across your site today while looking for info on this matter and I hope you can help. Thank you for your help.
Griff
  • shane1 likes this
#2 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 21 April 2013 - 10:51 AM
<br />DROID RAZR M Utility 1.10 --- Windows/Mac/Linux<br /><br />Try that. Run option 1 and wipe data when prompted. Make sure you are in ap fastboot. It takes a while so don't freak out. It will hang a bit while writing system.IMG which is normal since the IMG is so big. That should take you back 4.1.1. You can then either root with the utility, protect root with voodoo and take the ota. Or take the ota and root with motochopper which I will link to in the next post.<br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
  • neckchop and shane1 like this
#3 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 21 April 2013 - 10:53 AM
Root tool
<br />[ROOT] Motochopper: Yet Another Android Root Exploit<br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
  • shane1 likes this
#4 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 21 April 2013 - 11:01 AM
I took update and fastbooted back to 4.1.1 just fine lol I tested it last night with matt utility
#5 Griff
Griff
  • 17 posts
Posted 21 April 2013 - 11:16 AM
Will give the above a try, Thank you so much! fingers crossed.
#6 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 21 April 2013 - 11:22 AM
I don't think it will work if your still locked though
#7 Griff
Griff
  • 17 posts
Posted 21 April 2013 - 11:24 AM
[*] Simple Razr Restore
[*] Windows Version
[*] Created by mattlgroff
[*] Before continuing, ensure your Razr is in the
[*] "AP Fastboot" mode and connected via USB.
[*]--- Also press the keys after the screen flashes back on when asked---
[*] If your battery is low do NOT run this program Charge Charge Charge!
sending 'sbl1' (100 KB)...
OKAY [  0.020s]
writing 'sbl1'...
OKAY [  0.460s]
finished. total time: 0.480s
sending 'sbl2' (126 KB)...
OKAY [  0.020s]
writing 'sbl2'...
OKAY [  0.970s]
finished. total time: 0.990s
sending 'sbl3' (512 KB)...
OKAY [  0.050s]
writing 'sbl3'...
OKAY [  0.950s]
finished. total time: 1.000s
sending 'rpm' (140 KB)...
OKAY [  0.020s]
writing 'rpm'...
OKAY [  0.470s]
finished. total time: 0.490s
sending 'tz' (192 KB)...
OKAY [  0.020s]
writing 'tz'...
OKAY [  1.070s]
finished. total time: 1.090s
sending 'aboot' (256 KB)...
OKAY [  0.030s]
writing 'aboot'...
OKAY [  0.710s]
finished. total time: 0.740s
rebooting into bootloader...
OKAY [  0.000s]
finished. total time: 0.010s
 Waiting for a moment...
sending 'partition' (32 KB)...
OKAY [  0.020s]
writing 'partition'...
FAILED (remote failure)
finished. total time: 0.290s
OKAY [  0.020s]
writing 'sbl1'...
OKAY [  0.460s]
OKAY [  0.020s]
writing 'sbl2'...
OKAY [  0.790s]
finished. total time: 0.810s
OKAY [  0.050s]
writing 'sbl3'...
OKAY [  1.791s]
finished. total time: 1.841s
OKAY [  0.030s]
writing 'rpm'...
OKAY [  0.470s]
finished. total time: 0.500s
OKAY [  0.020s]
writing 'tz'...
OKAY [  1.370s]
finished. total time: 1.390s
OKAY [  0.030s]
writing 'aboot'...
OKAY [  0.720s]
finished. total time: 0.750s
sending 'boot' (10240 KB)...
OKAY [  0.770s]
writing 'boot'...
Preflash validation failed
finished. total time: 1.060s
sending 'system' (30720 KB)...
OKAY [  2.280s]
writing 'system'...
finished. total time: 2.600s
sending 'recovery' (10240 KB)...
OKAY [  0.770s]
writing 'recovery'...
OKAY [  2.960s]
finished. total time: 3.730s
sending 'modem' (30720 KB)...
OKAY [  2.550s]
writing 'modem'...
OKAY [  1.720s]
sending 'modem' (17576 KB)...
OKAY [  6.310s]
writing 'modem'...
OKAY [  2.890s]
finished. total time: 13.470s
sending 'devtree' (512 KB)...
OKAY [  0.050s]
writing 'devtree'...
OKAY [  1.310s]
finished. total time: 1.360s
erasing 'modemst1'...
OKAY [  0.640s]
finished. total time: 0.640s
erasing 'modemst2'...
OKAY [  1.160s]
finished. total time: 1.160s
sending 'fsg' (2794 KB)...
OKAY [  0.220s]
writing 'fsg'...
OKAY [  2.010s]
finished. total time: 2.230s
erasing 'cache'...
OKAY [  1.600s]
finished. total time: 1.600s
erasing 'tombstones'...
OKAY [  1.450s]
finished. total time: 1.450s
 It is recommended to wipe data, especially if you were on a custom rom.
 If you don't you will probably bootloop and have to wipe anyway...
 Press any key to Wipe the phone's data (might wipe internal SD card!)
 or exit the utility.
erasing 'userdata'...
OKAY [  2.670s]
finished. total time: 2.670s
OKAY [  2.280s]
writing 'modem'...
OKAY [  1.270s]
OKAY [  6.370s]
writing 'modem'...
OKAY [  2.530s]
finished. total time: 12.450s
OKAY [  1.330s]
finished. total time: 1.330s
OKAY [  0.600s]
finished. total time: 0.600s
rebooting...
 You are now on stock JB 4.1.1.
 Your device will now reboot and install radio files, then fully boot normally
Please make a selection or hit ENTER to return:
It never does restart^^^
#8 Griff
Griff
  • 17 posts
Posted 21 April 2013 - 11:27 AM
Ya still locked.  :(
#9 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 21 April 2013 - 11:32 AM
Yea some of it failed you can't downgrade while still locked
#10 Griff
Griff
  • 17 posts
Posted 21 April 2013 - 11:51 AM
Any other options?  Or is it time for a new phone?
#11 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 21 April 2013 - 11:55 AM
You can unlock if you want lol
#12 Griff
Griff
  • 17 posts
Posted 21 April 2013 - 12:03 PM
Sorry Brandon, can't tell if you are being sarcastic or what?   Is there nothing to do to remedy this situation I guess,
#13 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 21 April 2013 - 12:11 PM
Hmm well the 4.1.2 update must have flashed more then I thought. I figured it would fail due to frozen apps or something. Do you have another phone or an sdcard reader that you can load the 4.1.2 update on so you can side load it through stock recovery?<br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
#14 Griff
Griff
  • 17 posts
Posted 21 April 2013 - 12:47 PM
Sometimes after several times I can load up in normal startup. and phones works like normal. Can maybe DL 4.1.2 update if you have it or link to it Then manually install on sd card.
#15 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 21 April 2013 - 02:19 PM
I'm sorry. Stuck at the office. I will find it for ya. If your boots I would suggest plugging it in.
#16 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 21 April 2013 - 03:00 PM
No man lol I was being serious if you unlock your bootloader you can fastboot back easily
#17 Griff
Griff
  • 17 posts
Posted 21 April 2013 - 03:26 PM
Thank you
 for your help.~~ Phone is plugged in.
Thank you
 for your help. ~~  I do not know how to unlock phone. I have been looking but not info found as of yet.
#18 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 21 April 2013 - 04:07 PM
I'm still looking for the update. I have it on my computer but I won't be home for a few hours. If someone else has the update please post a link. Thank you. <br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
#19 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 21 April 2013 - 04:22 PM
I just pm a link for the update
  • tmyinc likes this
sig made by
Rinkle McBally
#20 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 21 April 2013 - 04:38 PM
Here's how to unlock make sure you read carefully if you wanna unlock
  • shane1 likes this
