Well installed the 4.1.2 update . Installed fine but still starts up in fastboot
fastboot reasn: Sticky bit factory_fastboot.
Any ideas. As for the above I had all the correct files needed to go to update.
Original boot screen is back after all three power button derpress and then normal startup. Works fine. Just no longer starts up like normal.
If you were stuck in AP fastboot you didn't need to flash an OTA because note that it says "flash failed" you could have just flashed something else like a custom boot logo, and problem solved.
