Best Answer tucstwo , 30 April 2013 - 06:41 PM
Are you rooted?<br /><br />Sent from my XT907 using Tapatalk 2<br /><br />
Yes, you need to re-root.
Have you tried rooting with Matt's Batman Utility Belt program?
Edit: You can also use it to install SafeStrap. :
http://www.droidrzr....- -Mac- -Linux-(All-In-One!)
Team RAGE
Proud Member & Co-Owner
Sent from my Motorola Droid RAZR Maxx running JellyBean 4.1.2 RAGE ROM 3.0 with the theme Slaytanic RAGE.
Please hit Thanks/Like if I have been helpful.
Yes This. These are the correct answers. Just having the Superuser or SuperSu app installed is not a final indication of being rooted. You need to go through the whole process again if you updated your software and didn't protect your root access with an app like Voodoo OTA Root Protector
Go to the full post
