What's Causing My Battery Drain?
Posted 08 April 2012 - 08:44 AM
I decided to let my battery run down to zero last night and let it charge while I sleep. I got to work this morning and just notice my battery is at 50%! The only change I really made yesterday was re-enabling smart actions, and setting a wifi connected trigger to turn data off. I'm thinking this may be the cause of the drain. Here are some screens.
Posted 08 April 2012 - 08:49 AM
Posted 08 April 2012 - 09:52 AM
(Maxx with normal use and LTE on all day yesterday)
Posted 08 April 2012 - 01:55 PM
Posted 13 April 2012 - 08:20 PM
Posted 13 April 2012 - 08:31 PM
I would ditch the chrome beta and k9 mail. Also disable any auto sync. It should give at least a 30 min battery extension
I ended up going back to Gummy on 173. When I was at home on wifi I would be fine but once on 4g it would have horrible drain. I might retry in the next week or so.
Sent from my DROIDRAZR using Tapatalk
Posted 17 April 2012 - 05:26 AM
Posted 17 April 2012 - 10:43 AM
Posted 17 April 2012 - 01:53 PM
#10 Guest_BDH_*
Posted 18 April 2012 - 12:22 AM
It was narrowed down to the radio constantly trying to grab a 4G signal. I'm back on Eclipse now.
Why not just put the network on CDMA Only?
Sent from my ICS RAZR using Tapatalk 2
Posted 18 April 2012 - 01:15 AM
That's like asking why someone wouldn't want to break up with their girlfriend because they can do it themselves.
Shameless promotion for Tapatalk v2 on some mobile device
:-D :-D
#12 Guest_BDH_*
Posted 18 April 2012 - 08:28 PM
I assume you don't line in a 4G coverage area?
I actually do live in a 4G area. However, battery life is more important to me than 4G. Since it's such a problem for the OP, I suggested he turn it off.
Posted 19 April 2012 - 07:48 AM
Posted 19 April 2012 - 08:39 AM
I have great 4G coverage. I'm sitting at work in a reinforced concrete building with 4G full bars, 74 dBm. Don't know whats up with the leak and my phone.
The leak drains my battery also. I tested it over night and it went from 100% to 78% in 6 hours. I'm on the original RAZR. My thunderbolt only lost 10% at the most sitting over night.
#15 Guest_BDH_*
Posted 19 April 2012 - 09:30 AM
That's good battery life. I'm in a 4G area and my battery drops about 10% every 40 minutes. Original Razr.
Posted 19 April 2012 - 09:31 AM
Posted 19 April 2012 - 09:33 AM
When connected to 4g I would lose 50% in 4 hours. It was atrocious.
Without touching the phone? During my test i was asleep so the screen never came on.
Posted 19 April 2012 - 09:43 AM
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Posted 19 April 2012 - 11:44 AM
I am on stock right now and get about 16 hours before hitting 40%. My wifes RAZR was at 15% after 4 hours today. Her stats showed that "rild" had used 56% of her battery. I have no clue what rild is lol
Google says it stands for Radio Interface Layer Daemon. Is your wife in a weak 4G area?
Posted 19 April 2012 - 11:47 AM
We are in a no 4g area and I have her phone set up to CDMA only.
