Non CM based roms fail to flash in TWRP with unlocked bootloader, please help
9 replies to this topic
#1 luigic81
luigic81
  • 9 posts
Posted 30 April 2013 - 10:28 AM
Any non CM based rom, wont flash for me, it says failed when I try to flash. I removed safestrap after I installed TWRP, any suggestions? Thansk!
#2 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 30 April 2013 - 10:49 AM
Are you mounting system prior flashing??
#3 luigic81
luigic81
  • 9 posts
Posted 30 April 2013 - 10:51 AM
I was not, let me try that :)
  • Memnoch73 likes this
#4 marinejargon
marinejargon
  • 5 posts
  • Google+:+Pat Brown Jr
  • Current Device(s):Droid Razr HD rooted unlocked
Posted 30 April 2013 - 09:49 PM
I'm having the same problem, although I mount the system prior to flashing and it says successful. After flashing and "rebooting" I get nothing but a black screen and I have to boot it manually into safestrap recovery. Any suggestions?
#5 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 30 April 2013 - 10:07 PM
Yeah, stop using SS if you're unlocked. If you're using SS on a locked device, you don't need to mount anything. If you are unlocked, get rid of SS and use TWRP or CWM exclusively.
  • Aixelsyd likes this
#6 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 01 May 2013 - 05:18 AM
If you are mounting system first then wiping anything on the device before flashing odds are that is the problem. Wipe everything first, then reboot recovery to follow up with mounting system then flash the ROM
  • RikRong likes this
#7 marinejargon
marinejargon
  • 5 posts
Posted 05 May 2013 - 03:20 PM
So I uninstalled SS from the stock app remover but I can still boot into SS. How do I completely remove it? My apologies for replying so late, been pretty busy lately.
#8 jsnweitzel
jsnweitzel
Posted 05 May 2013 - 03:57 PM
Reinstall safe strap and uninstall the recovery within the safe strap app.
#9 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 05 May 2013 - 03:59 PM
you have to disable ss before uninstalling it.
sig made by
Rinkle McBally
#10 marinejargon
marinejargon
  • 5 posts
Posted 05 May 2013 - 05:54 PM
Success!!! disabled, cleared and uninstalled. Thanks for your help shane!!!
  • shane1 likes this
