Razr HD Help... a little lost
13 replies to this topic
#1 ComplexPi
ComplexPi
  • LocationVancouver, Canada
  • Current Device(s):Razr HD
Posted 02 May 2013 - 09:18 PM
Hi guys,
So I'm actually posting about my girlfriends Razr HD.  She bought this phone months ago and I've helped her put SS and new ROMs on it and now we want to use the new ROM's that need the new Kernel and we figured it's just easier to stop using SS and use TWRP like any other phone.  However, I did this so long ago that I don't remember what are the right methods for RSD-lighting back to a stock ROM, so I was wondering if you guy could help.
Here's the scenario:
  • Currently on 4.1.1 (I believe) on the stock rom slot
  • Using SS
  • Currently running Nexesque (which needs the 4.1.2 kernel for Wifi to work)
  • Is actually the XT925 (I know there's a GSM forum, but the XT926 ROMs are SO much better!)
  • Bootloader unlocked
We want to:
  • Get rid of SS
  • Update to 4.1.2
  • Flash TWRP
  • Flash Nexesque again
Can anyone point me in the right direction?  I remember finding instructions to install SS was a pain in the rear end since we have the GSM version.  Also, I've long since switched to using BBOS10 so I'm not as savvy with Android anymore...  The more detail the better, thank you very much!
#2 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 03 May 2013 - 04:51 AM
Use
to return to stock and root
Use
 to unlock your bootloader
Use
 to install TWRP
Flash Rom
Profit?
  • shane1 likes this
#3 ComplexPi
ComplexPi
Posted 05 May 2013 - 09:50 AM
Awesome, thank you, that worked great except that now I'm not getting any cell signal.  I was on Verizon firmware before, but was still able to get signal.  I'm not sure why it doesn't work now.  Will flashing a Rogers Radio make it pick up signal again?  (Once again, I'm using all the XT926 firmware on my XT925 device)
#4 chuYxP
chuYxP
  • LocationNavojoa
  • Current Device(s):Motorola RAZR i XT890
Posted 19 August 2013 - 04:42 PM
Can someone help me? I have a XT925 with stock veryzon 4.1.2 (XT926 firmware). I'm stuck in fastboot mode, my Bootloader is LOCKED, thats really weird because I was unlocked before I've tried to update via OTA (my phone y bricked after that OTA update fail). I tried to flash Retail Brasil JB and some other firmwares via fastboot and RSD Lite 6.1.5 with no results... this is what my fastboot screen shows up:
Device is LOCKED, Status Code: 0
Battery OK
Connect USB
Data Cable
downgraded security version
update gpt_main version failed
failed to hab check for gpt_backup: 0x35
failed to load GPT
CID Read failure
Invalid CID status 0x69
No SP partition found
Fastboot Reason: Invalid GPT
Hope you can help me :S
#5 livinginkaos
Posted 19 August 2013 - 06:24 PM
Ok. Of You were unlocked you would still be unlocked. That doesn't go away by flashing firmware. Secondly, what the error says is that what you are trying to flash is an older security firmware than what you currently have and it will not let you roll back. You will need to flash the 4.1.2 comparable to the 4.1.2 you currently have. Since the flan failed your device will boot into fastboot until something flashes successfully. You can simply flash a boot logo and it will clear the fastboot and you will be back to where you started.
From My S4 Dev Edition
  • chuYxP likes this
#6 dlfns13
dlfns13
Posted 26 August 2013 - 07:08 AM
I am having same problem...how do I flash a boot logo?
#7 johnthehillbilly
Posted 26 August 2013 - 07:30 AM
Instructions for flashing boot logo can be found here
.... you should be having fun ...
#8 chuYxP
chuYxP
  • LocationNavojoa
Posted 27 August 2013 - 08:28 PM
I couldn't flash anything and I ran out of options and battery so I sent my phone to Motorola. Maybe in 7 more days I can see what they say, hope they didn't notice that I unlocked my bootloader :s
#9 cmh714
Posted 09 September 2013 - 11:09 AM
Moving to: VZW Droid Razr/Razr Maxx HD General [XT926] - {Q&A, Discussion}
Reason: Non-emergency
#10 wapiti_j
wapiti_j
  • 33 posts
  • Current Device(s):nexus7, razrm
Posted 05 January 2014 - 02:53 PM
I also have this issue.  I can fastboot reboot and it goes right back to the AP Fastboot screen with the previously mentioned error.
When I try to flash a new logo I get:
sending 'logo' (854 KB)...
OKAY [  0.074s]
writing 'logo'...
Invalid partition name logo
FAILED (remote failure)
finished. total time: 0.206s
Furthermore, when I try to RSD I get different failures:
with Android 4.1.2 Blur_Version.98.30.1.XT907.Verizon.en.US the error is:  Failed Flashing Process. Unknown fastboot command. (getvar)
with Android 4.1.2 Blur_Version.98.16.3.XT907.Verizon.en.US the error is: Failed Flashing Process. Unknown fastboot command. (getvar)
with Android 4.1.2 Blur_Version.98.16.1.XT907.Verizon.en.US the error is  Failed flashing process. 1/19 flash partition "gpt_main0.bin" -> Phone returned Fail
with Android 4.1.2 Blur_Version.98.15.66.XT907.Verizon.en.US the error is Failed flashing process. 1/19 flash partition "gpt_main0.bin" -> Phone returned Fail
I am really stuck here.  Anybody have an idea?
#11 johnthehillbilly
Posted 05 January 2014 - 02:58 PM
Um..... You have the HD .... Xt926?.... You are trying to flash the xt907 (M) files......
#12 SamuriHL
  • 43,456 posts
Posted 05 January 2014 - 03:02 PM
Their device list shows razrm.  I'm guessing posted in the wrong area.  However, they have NO clue about "flashing different versions" and why that's "ungood".  Fix the XML file by removing the getvar lines and flash the proper FXZ.
  • johnthehillbilly likes this
#13 johnthehillbilly
Posted 05 January 2014 - 03:05 PM
:):)device list is a bit harder to see using tapacrap... Lol :):)
#14 SamuriHL
  • 43,456 posts
Posted 05 January 2014 - 03:06 PM
I know, which is why I mentioned it.  :)
