Using a XT926 HD on 4.1.1 as the stock rom with Locked bootloader. I want to stay on 4.1.1 so i can keep root with out unlocking bootloader.
When using any 4.1.2 rom in a slot. None of them seem to have a working wifi. If i put a 4.1.1 rom in a slot wifi will work. Some have said it is the Kernel is the cause of this. So not knowing for sure im trying to install The RageHD 1.1 with the Kernel that is on the first page of the rom. I have the stock Kernel version of 3.0.31-g59a8475
#1. Is this the right Kernel for the 4.1.2 roms? If not what version should i be on and how do i install it. Or is there some kind or work around to get the simple Regular Wifi to work on the new 4.1.2 roms? Wifi slider is there and moves but it moves back to off on its own. What is the deal with this.Thanks
