Superuser Fails To Get Manifest On Ics Leak
Posted 12 April 2012 - 03:14 AM
I follow the sideload instructions to the T.
When I try and update my SU Binaries, I get the following error:
Failed to download manifest. Check Internet connection
Downloaind manifest.... FAILED!
etc....
My internet works fine for everything else, even OTA updates.
I've googled the crap out of this issue.
Tried connecting to a new WiFi - and even going off of 4G - Didn't Work
Went to System/bin/ and Deleted SU - Didn't work
Tried RSDing / Factory Reset - Didn't work
Even tried not upgrading Superuser - Still nothing.
I'm kinda at a loss as to why my SU is failing.
Any ideas?
Posted 12 April 2012 - 03:19 AM
Posted 12 April 2012 - 03:32 AM
FYI...I tried 5 different busybox installs 4 installed but still failed...FYI Im running Black Widow. I think its SU servers are down. IDK.UPDATE-- On stock 173 & same message. Definitely SU Servers...
Sent from my DROID RAZR on BLACK WIDOW!! using Tapatalk 2
Posted 12 April 2012 - 04:09 AM
So, I've had this issue where I can't maintain root (for whatever reason) when upgrading to the ICS leak.
etc....
Any ideas?
Maybe you already did this but update su prior to installing the leak
Posted 12 April 2012 - 04:36 AM
Posted 12 April 2012 - 05:14 AM
Also when I use rom toolbox to reboot I get a message saying superuser is not running.
Posted 12 April 2012 - 05:54 AM
Sent from my DROID RAZR using Xparent Red Tapatalk 2
- cynnar likes this
Posted 12 April 2012 - 07:07 AM
- cynnar likes this
Posted 12 April 2012 - 08:35 AM
Posted 12 April 2012 - 08:49 AM
Update: it seems that su was installed, but wasn't. Voodoo said wasn't rooted so I restored and fixed that problem.
Posted 12 April 2012 - 12:14 PM
- cynnar likes this
Posted 12 April 2012 - 12:18 PM
Posted 12 April 2012 - 11:40 PM
