sending HD back is there a way to un-root so it does not show up as it WAS rooted?
speaker went out! not speaker phone other internal
Posted 09 May 2013 - 04:10 PM
Posted 09 May 2013 - 06:47 PM
Matt has a nice app on the playstore to unroot. The qe will always show 0/1 if you unroot but not sure if they ever look at that. If you want to do it manually you will need too use root explorer and remove your superuser app, then navigate to system/bin and remove the su binary and busybox then reboot your phone.
Posted 11 May 2013 - 12:34 PM
What is the app called? thanks I'm lloking for the same advice.
Posted 11 May 2013 - 01:06 PM
Universal Unroot
