Need A Contacts Widget For Ics
3 replies to this topic
#1 psyjohn
psyjohn
  • 65 posts
Posted 14 April 2012 - 05:05 PM
Does anyone know of a good scrollable contacts widget that will work on the ICS leak?
I used to use one called photocontact but it won't work now, even with Apex Launcher installed. I've tried a couple others I found in the play store but haven't liked anything so far.
#2 quangtran1
quangtran1
  • 243 posts
Posted 15 April 2012 - 04:30 AM
Android Pro Widgets
  • psyjohn likes this
#3 psyjohn
psyjohn
  • 65 posts
Posted 15 April 2012 - 05:26 PM
Thanks quangtran1! Exactly what I was looking for.
#4 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 15 April 2012 - 05:27 PM
Android Pro Widgets
+1 for APW. Great widget with theme options if you are into that.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
