I need little help..
17 replies to this topic
#1 carlos12313
carlos12313
  • 7 posts
  • Locationnew york
Posted 16 May 2013 - 12:48 PM
This my problem, i have a Razr with no rom installed. I am trying to get 4.0.4 ICS clean will be install it USB.
I am looking to setup for GSM open unlocked ready to use.
Give me some link to download any Flash Rom installation fresh working stable.
Thanks.
#2 johnthehillbilly
Posted 16 May 2013 - 01:09 PM
If your phone is ICS you can use the 1.82 utility ...
... That will give you a fresh clean ICS 4.0.4
If you have been updated to JB then you can use this one ...
That one will get you a fresh clean JB 4.1.2
tapadriving......hillbilly style
#3 carlos12313
carlos12313
  • 7 posts
  • Locationnew york
Posted 16 May 2013 - 01:20 PM
Great i am going to give it try , i will post the outcome...
#4 carlos12313
carlos12313
  • 7 posts
  • Locationnew york
Posted 16 May 2013 - 05:16 PM
ok it when well but i get this message "Unfortunately, Motorola service has stopped." do you know what it can be..
#5 johnthehillbilly
Posted 16 May 2013 - 05:22 PM
Which one worked for you? :)
Try rebooting into recovery, either stock or safestrap(if you installed safestrap)
Wipe/clear cache and/or dalvik cache then reboot......
[Moving to RAZR xt912 help]
#6 carlos12313
carlos12313
  • 7 posts
  • Locationnew york
Posted 16 May 2013 - 06:15 PM
I have try the first one
but when though the links it link me to 4.1.2 now i have that.. It seem to be working only that little error.. I just rooted it now..
I just need to unlock it..
I am going to try safe mode clean cache
#7 johnthehillbilly
Posted 16 May 2013 - 06:25 PM
As far as "unlocking" what exactly are you looking to do?
The boot loader cannot be unlocked on the RAZR (xt912)
#8 cmh714
Posted 16 May 2013 - 06:36 PM
What hillbilly said!! We unfortunately cannot unlock our XT912. Root is the best we get, which is damn good.
#9 carlos12313
carlos12313
  • 7 posts
  • Locationnew york
Posted 17 May 2013 - 05:45 AM
I want to use GSM chip on this phone, Do we have anything to let me do it.
If we do tell me i will follow your instruction if we don't .. Thanks for your time and great help .
#10 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 17 May 2013 - 05:47 AM
You have to put a local GSM sim in the phone and it will work
#11 livinginkaos
Posted 17 May 2013 - 05:48 AM
Edited - wrong link
#12 johnthehillbilly
Posted 17 May 2013 - 05:49 AM
It is a "global" device.... a local GSM sim card should work for you :)
tapadriving...... hillbilly style
#13 johnthehillbilly
Posted 17 May 2013 - 05:53 AM
Wrong link
That seems to be for the M and the HD .... .. not sure it would work for the xt912
#14 livinginkaos
Posted 17 May 2013 - 05:56 AM
Yep, grabbed the wrong bookmark - thanks for catching !  Will edit.
#15 johnthehillbilly
Posted 17 May 2013 - 06:02 AM
No worries bro :)
#16 carlos12313
carlos12313
  • 7 posts
  • Locationnew york
Posted 17 May 2013 - 06:09 AM
Well i am going to try it anyways it doesn't hurt to try : livingingkaos
I do know that radio attenna doesn't show active even if does or doesn't have a chip. That is strange i would expected to be connected to Virizon as pick up signal. Has anyone seen that before because i was thinking something wrong with phone internal.
#17 cmh714
Posted 17 May 2013 - 02:52 PM
If your looking to make the GSM work here in the US, I dont think thats gonna happen. If you do so in a foreign country then yes GSM works.
#18 carlos12313
carlos12313
  • 7 posts
  • Locationnew york
Posted 20 May 2013 - 03:38 AM
Yeah, i gave up on it..It seem that i don't get any signal strength show on the phone. I believe this phone is damage because it doesn't show LTE/CDMA ether.
Thanks for all the phone you guys have made my life easy if anything i will posted up for now thanks.
