[Mod]Droid Razr Ics Leak - Deodexer
#161
Posted 05 May 2012 - 10:44 AM
Sent from my DROID RAZR using Tapatalk 2 Beta-5
#162
Posted 15 May 2012 - 04:36 AM
I thought that after the flash. You would have another tab in the settings you would use to mod with. I have not clue how to use it then for modding. Sent from my DROID RAZR using Tapatalk 2 Beta-5
I had to google it because I wasn't sure, but to put it simply, our stock system is odexed. Meaning files are sometimes split up, which allows the system to read it faster, but that makes it harder to mod. With an deodexed system the files are put back together, making it easier to mod. I really have no experience modding...but hopefully this answers your question.
#163
Posted 15 May 2012 - 06:15 AM
#164
Posted 15 May 2012 - 06:17 AM
It does that you. So like disk defragment for a computer.
It's more or less a stock deodexed rom.
Sent from my RAZR Maxx using Tapatalk 2
#165
Posted 12 June 2012 - 11:15 AM
#166
Posted 12 June 2012 - 11:17 AM
Sent from my full_spyder using Tapatalk 2
#167
Posted 12 June 2012 - 11:18 AM
EDIT: Whoops, haha sorry, beat me to it!
#168
Posted 12 June 2012 - 11:31 AM
#169
Posted 12 June 2012 - 07:02 PM
Thanks for the info
#170
Posted 14 June 2012 - 06:21 AM
#171
Posted 14 June 2012 - 09:28 AM
#172
Posted 19 June 2012 - 07:56 AM
Not really possible for one main reason. To deodex isn't just running a script. Its a process of converting the odex files to a classes.dex then inserting that back into the apk that its intended for. That said the deodexer replaces all of system /app and /framework files that have had that process done to them.
true say.. i had a go at deodexing the gsm version on the weekend.. long process but managed to do all framework & app files except for the notorious blur-services.apk&.odex lol
#173
Posted 19 June 2012 - 09:56 AM
i still look forward to being able to deodex the stock ics rom.
+1
Sent from my WC using Tapatalk 2
#174
Posted 20 June 2012 - 07:09 AM
