How Do I Enter Ap Fastboot Mode?
11 replies to this topic
#1 jtcgiants56
jtcgiants56
  • 8 posts
Posted 24 April 2012 - 10:46 PM
I'm trying to restore my razr to 6.12.173 using the droid RAZR utility and its saying that I need to enter AP Fastboot mode before I can do the restore. I haven't even been able to find an answer on google. Can anyone shed some light on this for me? Thanks.
#2 kaplac
kaplac
  • 102 posts
Posted 24 April 2012 - 10:53 PM
Turn off your phone.
Press and hold the following buttons at the same time until the screen turns on
1) volume down
2) volume up
3) power
Press Volume down until you reach the AP fastboot in the list
Press Volume up to select
  • Thach, The Persuader and bigabedog19 like this
#3 Guest_BDH_*
Guest_BDH_*
Posted 24 April 2012 - 11:53 PM
Power off phone
Press and hold volume down and power button
When the screen flickers release only the power button.
  • Thach, karnovaran and The Persuader like this
#4 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 25 April 2012 - 03:09 AM
This works just as well as the utility.
#5 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 25 April 2012 - 04:31 AM
What system version are you running?
#6 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
Posted 26 April 2012 - 07:01 PM
Did you ever get it all figured out?
Sent from my DROID RAZR using Xparent Red Tapatalk 2
#7 jtcgiants56
jtcgiants56
  • 8 posts
Posted 27 April 2012 - 01:26 PM
Yeah, sorry for not responding. I was able to boot into fastboot mode and then use the utility to restore back to 6.12.173. Installed ICS after and its been running smooth like butter ever since.
#8 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 27 April 2012 - 03:41 PM
For future reference to anyone that doesn't know... if you're on your ready to use the utility or any other reason yiu need to get to fastboot... an easy adb command is "adb reboot-bootloader" gets you straight to fastboot... and youre already plugged in! Lol
  • PsyberEMT and rstueven like this
#9 PsyberEMT
PsyberEMT
  • 24 posts
  • LocationCharleston, SC
Posted 21 August 2012 - 06:24 AM
You saved my butt with this. My volume keys stopped working so I couldn't get in to fastboot back to stock the normal way before sending it back for a warranty replacement. I could soooo see VZW denying a hardware defect warranty claim because a phone was rooted *facepalm*
"No trees were killed to send this message, but a large number of electrons were terribly inconvenienced" -- Dr. Neil deGrasse Tyson
#10 tucstwo
  • Google+:tucstwo@gmail.com
Posted 21 August 2012 - 06:43 AM
i'm sure they'd use any crutch they could get their weaselly hands on.
#11 Dreadlord12p
Dreadlord12p
  • 10 posts
  • Current Device(s):Motorola RAZR
Posted 03 December 2013 - 08:13 AM
I had my phone rooted and it had a defect and I had Superuser and a bunch of rooted things on it and they still shipped me a new Refurbed phone and they didnt even charge a dime!
  • The Persuader likes this
#12 muratuzun
muratuzun
Posted 16 January 2014 - 11:30 PM
Power off phone
When I lost all my hopes, you saved my phone!!! Thank you so much.
