Hello fellows,
I have been using my RAZR HD for almost 6 months with no major issues to speak of. Recently i decided to bite the bullet and unlock the bootloader and tried out the ROM, Rage HD v1.1, and i really enjoyed it. But after a week i started having issues with my microphone. First my mp3 recorder started giving me error messages when i attempt to record saying to close other apps that might be using the microphone. Next phone calls stopped sending my voice, although i can hear the other side just fine. Using a headset allows me to still use the phone for work and all but it is a real drag not being able to use my phone as a tuner for my cello like i used to. It seems like an app may be causing this because i have since wiped the device and tried the Slimbean ROM, and the voice search worked once in 'google now' but is currently dysfunctional.
Has anyone else heard of this issue and would anyone know how i can solve it? I'm going to try a fresh rom again with none of my apps installed and see if that can narrow down the culprit.
Thank you,
Random_Khaos
