anyone know the numerical codes for the colors that the notification light can use?(i.e. the blue that i use for various things is #ff0032ff)
notification light colors
Posted 28 May 2013 - 02:07 PM
Posted 28 May 2013 - 02:33 PM
you can use pretty much anything that that led will produce, this website will help out (i feel)
on the top is the little changer you can mess with to check colors and their codes
the thing is, i've tried several different colors, and had the light be white when i tried it...there are probably millions of different colors available, and only a certain few of those will the led produce...i'm wondering if anyone has done the leg work so i don't have to spend 3-4 days trying all the different combinations
Posted 28 May 2013 - 11:52 PM
00ff00 - green
ffff00 - yellow
ff00ff - purple
0000ff - blue
ffffff - white
ff0000 - red
Sent from my CM 10.1 XT926
- badjedi and zekemo like this
Posted 29 May 2013 - 05:19 AM
also, it'll display the ff0032ff version of blue too, but it'll only display it as the blue of 0000ff
Here is what I have so far:
00ff00 - green
ffff00 - yellow
ff00ff - purple
0000ff - blue
ffffff - white
ff0000 - red
that's the kind of info i'm lookin' for...thank you
Posted 30 May 2013 - 07:31 AM
For some reason, certain colors won't work unless they are non-flashing. For example, using Light Manager, I can only get orange to show if the LED does not flash. If I set it to flash, it will be yellow.
So, I'm not sure if this can be fixed, seems like there's something that can be changed in the code but heck if I know! I'm just an end-user
Posted 02 August 2013 - 04:06 PM
Another one for you guys to check out if you wanted a light blue/cyan color is 00FFFF. Thankfully I found this thread and linked it in the unofficial release thread
