Posted 28 April 2012 - 02:25 PM
folow instructions which is in the zip. the cdt file that is in here is from the .84 leak
- cynnar likes this
Posted 28 April 2012 - 02:28 PM
Posted 28 April 2012 - 02:29 PM
Posted 28 April 2012 - 02:32 PM
Posted 28 April 2012 - 02:34 PM
Edit: I'm also curiosu if you know as I hadn't updated to the new leak. When trying to flash back using the fastboot file that casued it to brick is the CDT.bin the file that caused the bricking to happen?
Posted 28 April 2012 - 02:37 PM
Posted 28 April 2012 - 02:39 PM
its from the .84Which CDT.bin file is that in your link? IE is it from the 84 or the 75 build of ICS
Posted 28 April 2012 - 02:50 PM
Posted 28 April 2012 - 03:03 PM
yes this is the one from the 84 that caused the hole brick to happen when they changed it.Which CDT.bin file is that in your link? IE is it from the 84 or the 75 build of ICS
Damn, my battery is @ 5%. I'll let you know how it works when I'm charged up
Good luck! Fingers crossed for you bro!
[ 43V3R IC3'd on .84 ]
Posted 28 April 2012 - 03:10 PM
gl man let me know pm or post it hereDamn, my battery is @ 5%. I'll let you know how it works when I'm charged up
Posted 28 April 2012 - 03:29 PM
someone with a brick should try flashing the 75 CDT.bin and see if it passed. If so and it boots up then could try fastbooting back to 173 then and see if it finishes up like we would all like it to so bricks can be saved.
Read commands after "battery low fail"
Posted 28 April 2012 - 03:47 PM
Posted 28 April 2012 - 04:23 PM
no i just let it boot up and u should be on .84Knght50, what should the phone do after the moto logo? or did you try to fastboot back to something?
Posted 28 April 2012 - 04:26 PM
Flashing the old cdt doesn't work. Says invalid.
Posted 28 April 2012 - 06:01 PM
failed @ 6/21
Posted 28 April 2012 - 06:51 PM
Wont work. I tried long before I posted my thread.
Posted 28 April 2012 - 07:44 PM
Unless by some chance a dev figures out how to force it to flash I don't see how it's possible.
Also tagged with one or more of these keywords: ics, brick, fix
