#21
Posted 28 April 2012 - 07:52 PM
I seem to remember that p3 reverted the system for the bionic so that a fastboot was possible... but was the bionic's bootloader unchanged? I can't seem to remember...
My thought is simple. If it's a bootloader incompatibility, we're in for a tough or impossible fix. But if it's a system incompatibility, then all we need to do is successfully change our system to 173 or 181. And for that we would just need to get a GB system to run on an ICS kernel. Basically the opposite of what STS dev has been doing. Possible?
It probably wouldn't work for RSD but might for a manual CLI process.
Thoughts?
[ 43V3R IC3'd on .84 ]
#22
Posted 29 April 2012 - 05:58 AM
#23 Guest_BDH_*
Posted 29 April 2012 - 12:22 PM
From what I gather it is a bootloader issue. Otherwise an Advanced System Restore from a NAND would work. But thats been tested and the phone just boot loops. It doesn't like to run GB on the ICS kernel.
You are correct, the .84 and the .85 leak have an updated bootloader. That's what is causing the issues with fastbooting.
#24
Posted 29 April 2012 - 12:27 PM
#25
Posted 29 April 2012 - 02:11 PM
#26
Posted 29 April 2012 - 02:23 PM
#27
#28
Posted 29 April 2012 - 02:24 PM
#29
Posted 29 April 2012 - 03:27 PM
For what it is worth, the whole reason I went from Microsoft to Android and not IOS was because of the "open" nature of Android. My replacement will be a Samsung since they served me so well with the Microsoft phones I had. My first Android was the Droid X, then the Xoom, then the Bionic, then the Razr Maxx. TTFN Moto - never again! Hello Sammy.
#30
Posted 29 April 2012 - 03:55 PM
The reality is, the bootloader will fail on everything until someone finds a way around it. There are many various ways listed to restore the Razr, but none of them work and if you try them you will have the brick that I now have. My replacement will arrive on Tuesday.
I understand your frustration, but sammy phones feel cheap...moto needs to lighten up...hope the dev phones help them save face...if they don't rape us on them...
#31
Posted 29 April 2012 - 04:00 PM
#32
Posted 29 April 2012 - 04:01 PM
#33
Posted 29 April 2012 - 04:44 PM
I own a Samsung Galaxy Note i717 on AT&T and fine it to be remarkable. Moto does build more substantial devices, but Samsung has figured it out. I have been able to go back and forth between Gingerbread and ICS with no problems. The screen quality is amazing. The battery, well that is why I have the Razr....
#34
Posted 29 April 2012 - 04:46 PM
Actually the reality is you should have waited on the leak to be tested before jumping into it. I always wait at least a day or so before i flash. Even on the first ics leak there where issues when first dropped. I knew the risk when i went back to motorola and locked bootloaders. You just have to ask yourself. Do you want a phone that works better than the rest or a phone that runs bleeding edge android? I like motorola for the most reliability and HTC for unlocked bootloaders. Samsung has nice screens and thats it. The facts dont lie. To each his own...
Yes, I know I should have waited. I have already taken myself to the woodshed and beat myself up over this. Even so, thank you for piling on. I really needed it (LOL).
#35
Posted 29 April 2012 - 09:53 PM
Dev phones=identical phones with unlocked bootloaders. Wouldn't everything just be better if they unlocked ALL the bootloaders??
#36
Posted 29 April 2012 - 11:40 PM
#37
Posted 30 April 2012 - 01:56 AM
So, that being said will we even be able to fasboot ICS OTA fastboot files once they are out?
#38
Posted 30 April 2012 - 05:36 AM
It is my understanding that as long as the "Official" OTA uses the same bootloader then YES we should be able to fastboot files once they are released.
#39
Posted 30 April 2012 - 11:04 AM
#40
Posted 30 April 2012 - 11:08 AM
Dumb question...could these bricked phones be sent back to Motorola for a total wipe and reload for a fee? Why don't people do that?
We knowingly and voluntarily voided the warrantee when we did this.
Also tagged with one or more of these keywords: ics, brick, fix
