Upset That This Leak Bricked My Device.
Posted 29 April 2012 - 05:03 PM
I wouldnt of been so careless and gung ho in flashing the leak(.84) if I knew it was not RSD flashable. That is the only reason I did flash it. Because I assumed I could flash back safely. I was running my regular setup which was working wonderfully. I just wanted to see if the new leak was good or not. Again assuming I could just go back to my other setup if I wanted to. I can understand if the leak was posted saying they werent sure if RSD would work or not. but it was stated that it DID WORK. very bad form. Arcan needs to own up to this issue and accept responsibility. As a senior member who is well respected at bringing well tested stuff, I trusted his work from his previous releases. I for one will not trust another again. This issue is going to severely discredit all the good work done by this website and other people here. I used to love coming here, and after this whole issue I get upset now each time I log on and see others in the same position as me. So many people got jacked over and all the Mods can say is well its the users fault since they flashed and they need to know what they are doing before they do it. I think thats BS....who finds out if something is safe to use for the masses? If someone like P3 says its safe, wouldnt others assume its safe? If a dev like Kejar says it works wouldnt you believe that? So, if someone like Arcan says its safe why would anyone question that? So, most would flash away trusting his word. While I still hold myself accountable because I am the one who flashed it, there is at least some percentage of the liability on the OP shoulders and all the others involved. Dont says its safe if your not 100% sure its safe..period..and if you say its safe and it really isnt then you have to accept some of the blame. I dont care if I get flammed or whatever for this post because I doubt I will ever come back to this site again. I am done here.
Posted 29 April 2012 - 05:11 PM
- pdumont1 and HunterH116 like this
Posted 29 April 2012 - 05:20 PM
sent from my rooted ICS running RAZR with bootstrap alongside with beats audio hack and a battery mod. have a nice day you iPhone hating friends.
- pcriz likes this
Posted 29 April 2012 - 05:22 PM
Posted 29 April 2012 - 05:24 PM
#7 Guest_DirtyDroidX_*
Posted 29 April 2012 - 05:26 PM
I flashed my leak from Arcanexi post not SPC hicks so this is not intended for him but directly at Arcan's thread. My phone is also hard bricked with no way of bringing it back. I tried all sorts of things including working directly with the mods on chat. I just need to vent.
The context don't matter. YOU AS A MEMBER except all responsibility, for anything that you do to your phone. Regardless of what the OP says. If you are looking for a loop hole or someone to blame your barking up the wrong tree.
Intact arcanexvi was at work and I tested the leak and two others did too. This is all symantecs, own up to your actions.
- Thach, captmilk, PillClinton and 2 others like this
Posted 29 April 2012 - 05:36 PM
The leak works perfectly fine, if you flash it then you have a device running 6.14.84/5 and only your own actions (attempting to flash backwards) have caused the situation you find yourself in. There is nothing that is foolproof, if there was then oems would never release updates for their devices.
I think you should look around and find a way to fix your device and then come back and teach the community. No one like to be without their phone, and especially one that you think is bricked. The good news is that you are not bricked, you are just temporarily unable to use your device. I've actually bricked 4 phones and nothing could recover them. So cheer up, you will be able to use your razr eventually, and hopefully sooner rather than later.
- captmilk and PillClinton like this
All the talk by mods and others have been about not releasing files that may harm the device permanently and I'm pretty sure the original thread mentioned it was fast boot able.
My only question to everyone with bricks is.....
why did you already try to flash back without a days usage of the new leak???
Posted 29 April 2012 - 05:42 PM
I accept that it is my fault for flashing the leak. I know the risk. With that being said I do not see anyone stepping foreword and admitting that this was not properly tested before it was slapped up on a site so someone could say they done it first. It is not a one sided coin. Yes you are responsible for what you do to your phone. Yes the information was incorrect. But to hate on those that chose there actions on false information is pure retarded. Besides if you do not expect the ones just after credit or bragging rights or whatever the hell reason for a misinformed post, then leave those alone that feel like they got screwed over and now have to buy a new phone.
Based on this information one should not believe anything any dev says PERIOD.
I feel sorry for those that are bricked. I hope that a fix can be found , but then again you better not trust them.
Now everyone can come in and say what they will about me. I really don't care. You have your opinion and i have mine.
I would not have flashed 84 if I would have known i would be stuck. I did however stop there and not try to flash back, so my phone still works.
If it's not broke try harder.
Posted 29 April 2012 - 05:48 PM
Posted 29 April 2012 - 05:49 PM
Posted 29 April 2012 - 06:01 PM
As far as taking full responsibility as a member I DO. Always have. Been doing this kind of stuff longer than most of you (no not just hacking droid) Hell I've been a tech geek for 18 yrs now.
But I guess the real moral here is even though you are told to read everything carefully, DON'T trust what those that claim they know what they are doing.
Sound about right?
Posted 29 April 2012 - 06:10 PM
Posted 29 April 2012 - 06:12 PM
- PillClinton likes this
Posted 29 April 2012 - 06:19 PM
Onto the next point. Everyone who messes with their phone is ultimately responsible for what happens. But, with that being said, I would also like to publicly come out and say that's it's bullshit that the higher ups said that this leaks was tested tested tested and then everyone bricked AND no one will take responsibility. The issues isn't that people bricked their own phones, the issue is that commoners (such as myself) look up to and trust the Devs and management of this forum and for those trusted individuals to come out and vouch for a specific flash and then cause a forum wide meltdown and REFUSE to take ANY responsibility is without a doubt the most irresponsibility taking place on this forum, beyond crack flashing. Yeah I said it. It's about owning up to screwing up and not about finger pointing or lack there of. I personally am not bricked but I feel for those who are because they foolishly trusted those who call themselves leaders but then claim 0 liability when the shit hits the fan. That's what being a leader is all about. A leader takes responsibility for his troops. When there's a scandal at a large company, the CEO gets shit canned. When there's a failure in a military drill, the commanding officer gets reprimanded, even if he wasn't even there! That's what being a leader is all about, taking responsibility for your subordinates actions when your directions are what caused the problem to begin with, otherwise, why have admin, testers, Devs and mods? Why bother if these people are so quick to point he finger and run for the door when their accountability has been jeopardized? I'm done, take this as you will. But if you can't lead..then DONT.
Posted 29 April 2012 - 06:31 PM
Your phones aren't even bricked... The same people who you think caused this are the ones working really hard to get your phones working again.
+10 on that!
I've been flashing roms since the first windows mobile phones and the best rule of thumb is:
1) Wait a couple days for all issues to be ironed out.
2) For the unexperienced, wait a week.
3) For the whiners that like to blame other people for their own mistakes and lack of experience! Do us all a favor and get an iphone and a pink hello kitty case to match!
- GeXX and crowbar3m like this
Posted 29 April 2012 - 06:35 PM
Posted 29 April 2012 - 06:40 PM
I'm also bricked tried fastbooting. Step 6 fail and brick. Filed a clam with asuron and I'm getting a new razr.
Posted 29 April 2012 - 06:41 PM
Worked with DrjBliss - Have fun getting root from him again. Maybe it will work here too.
I'm not even going to look at these threads anymore because it's rediculous.
Fact is, you have a $700 device in your hand. If you don't want to ruin it, then stick with stock. Mistakes happen and when they do this is the result. It's time to move on to bigger and better things
- eckdawg5 and pdumont1 like this
