Nandroid trouble
Posted 06 June 2013 - 03:10 AM
Posted 06 June 2013 - 03:24 AM
- eroupe117 likes this
sig made by
Rinkle McBally
Posted 06 June 2013 - 03:33 AM
Posted 06 June 2013 - 03:46 AM
sig made by
Rinkle McBally
Posted 06 June 2013 - 04:26 AM
O... I thought I was supposed to make a backup first... so I need to flash recovery first, then go from there... thank you I'll give it a shot today
Your backup is actually made in recovery. There is a backup option in the recovery menu.
- livinginkaos, shane1 and eroupe117 like this
Posted 06 June 2013 - 06:25 AM
Posted 06 June 2013 - 06:35 AM
Threw you off? Won't on external SD? What does it do?
Sig by
Posted 06 June 2013 - 07:29 AM
Posted 06 June 2013 - 09:09 AM
I don't know what that nandroid back up app is but you need to boot the phone into recovery and then choose back up. That will make an actual correct nandroid backup for you
- livinginkaos, RikRong and eroupe117 like this
Posted 06 June 2013 - 09:46 AM
Posted 06 June 2013 - 10:12 AM
OK, I am thinking that you have not installed a custom recovery at this point such as CWM or TWRP, is that correct? This is something you would want to do since you've unlocked the bootloader. It is in that recovery that you would want to perform your backup - not through an app. This gives you the best coverage if something goes wrong in a flash.
Sig by
Posted 06 June 2013 - 11:07 AM
Posted 06 June 2013 - 11:39 AM
Sig by
Posted 06 June 2013 - 12:31 PM
thank you for your help!
